Horn stopped working :(
Corey95
Post by Corey95 »
Went to use it made 2 small beeps then stopped working completely
Re: Horn stopped working :(
Time for an air horn upgrade mate
Corey95
Post by Corey95 »
Train spec style :P but seriously it just randomly stopped
Or musical, whatevs floats ya boat...
Wouldn't have a clue man, fuse?horn itself farkeditselfinthearse? Maybe there's connections behind the cover that aren't touching when u press it or someshit... Someone will tell ya lol
Fuse?
benrad666
Post by benrad666 »
Sounds like a bad connection, take your steering wheel off and check wires.
benrad666 wrote:Sounds like a bad connection, take your steering wheel off and check wires.
Plug into the clock spring.. If not fuse..
...or wiring at the horns themselves, the external wiring is subject to the weather and corrosion.
Bennoz wrote:Fuse?
PHIL069 wrote:...or wiring at the horns themselves, the external wiring is subject to the weather and corrosion.
Guizz
Hey guiz I covered all this sh*t guiz
Go see a doctor and get some little blue pills, that should get ya horn goin' :lol:
