Horn stopped working :(
- Corey95
Went to use it made 2 small beeps then stopped working completely
Re: Horn stopped working :(
Time for an air horn upgrade mate
- Corey95
Train spec style
but seriously it just randomly stopped
Or musical, whatevs floats ya boat...
Wouldn't have a clue man, fuse?horn itself farkeditselfinthearse? Maybe there's connections behind the cover that aren't touching when u press it or someshit... Someone will tell ya lol
Sounds like a bad connection, take your steering wheel off and check wires.
- rock_it
Plug into the clock spring.. If not fuse..benrad666 wrote:Sounds like a bad connection, take your steering wheel off and check wires.
...or wiring at the horns themselves, the external wiring is subject to the weather and corrosion.
Bennoz wrote:Fuse?
rock_it wrote:Plug into the clock spring.. If not fuse..benrad666 wrote:Sounds like a bad connection, take your steering wheel off and check wires.
GuizzPHIL069 wrote:...or wiring at the horns themselves, the external wiring is subject to the weather and corrosion.
Hey guiz I covered all this sh*t guiz
Go see a doctor and get some little blue pills, that should get ya horn goin'
