hahahahaSahin wrote:Could have said, matts heartsilverGPX wrote:Of all the cold places you could of said you chose Norwaydestinationtoby wrote:Could just move to Norway or something.. Shouldn't get too hot over thererock_it wrote:If the car still overheats, then not sure what else you can do...
Fans not always working
Re: Fans not always working
- rock_it
ROR!silverGPX wrote:hahahahaSahin wrote:Could have said, matts heartsilverGPX wrote:Of all the cold places you could of said you chose Norwaydestinationtoby wrote:Could just move to Norway or something.. Shouldn't get too hot over thererock_it wrote:If the car still overheats, then not sure what else you can do...
- Chebus
Just tested my car today and it did this, got to just under 1/2 and stoped. fans didnt turn on, what do?silverGPX wrote:Daniel, does the temperature gauge rise to a certain temperature on the gauge and then stop?
Or does it keep going to the H?
It takes a little while to start moving from a cold start (under the bottom/left line) then it rises until it gets to just under half, stays there for another little while then starts climbing up again. I have never let it get to above 3/4.
- fraz91
- Hair-do
You need to get hold of an infra-red gauge and point it directly at something on the hot side of the coolant flow (upper rad hose, thermostat housing, etc). Leave the engine running and use the temp given by the infra-red gauge to tell whether to turn it off or not. That's how I sorted the issue with the Barina, as the Barina's dash gauge didn't allow for much variation before it started moving wildly about (total gauge spanned 15degC with 8 marks between cold and overheating...).Daniel2019 wrote:It takes a little while to start moving from a cold start (under the bottom/left line) then it rises until it gets to just under half, stays there for another little while then starts climbing up again. I have never let it get to above 3/4.
You need to determine whether or not it's the gauge reading incorrectly or the sensor earthing out at the wrong temperature. The only way of doing that is to measure the actual temp of the water coming out of the engine and just before it enters the radiator.
Just change the cluster aye, come on mate
I think i need a reward if its the cluster.Sahin wrote:Just change the cluster aye, come on mate
- rock_it
silverGPX wrote:I think i need a reward if its the cluster.Sahin wrote:Just change the cluster aye, come on mate
Your reward would be you were right... Is that not enough ...
Here have a waffle #
If its the cluster then ill bring an extra case of beer to the bonfire for you c**nts
- fraz91
- Hair-do
Oooh look, I can make it blue!rock_it wrote:Here have a waffle #
I prefer waffles with lime syrupfraz91 wrote:Oooh look, I can make it blue!rock_it wrote:Here have a waffle #
Red ones for me!Astron_Boy wrote:I prefer waffles with lime syrupfraz91 wrote:Oooh look, I can make it blue!rock_it wrote:Here have a waffle #
- bjk
- Totes
I'm pretty sure you're all on drugs.
haha dan didnt get blue waffle
Jelly?bjk wrote:I'm pretty sure you're all on drugs.
I did..silverGPX wrote:haha dan didnt get blue waffle
Did you not get red waffle? The red sea.. Flowing red river.. blowjob week? Bleeding vagina?
No? Nothing?
I havent gotten any in a long time lol
- rock_it
To change topic a little...
Part it out...
Part it out...
As much as I would hate to, if it got to a water pump issue or something then Id be tempted.rock_it wrote:To change topic a little...
Part it out...
- rock_it
I think you would be better fixing water pump and selling rather than parting out... I am sure we could DIY day, and get a hand to do the pump if need be... I would do it for you, but am not that mechanically skilled... But will help where I can ...Daniel2019 wrote:As much as I would hate to, if it got to a water pump issue or something then Id be tempted.rock_it wrote:To change topic a little...
Part it out...
