All gone.
AMACHA
Post by AMACHA »
hey buddy can i grab the super power flow kit off you mate? so it pretti much comes with everything ill need to install it?so pretti much everything in this pic http://www.perfectrun.com.au/real_size_ ... loaded.htm
Also id like to grab the uas pipe off you as well mate does that come iwth everything i need to isntall it like the clamps and pretti much i wont nee to buy anything else to isntall it isthat correct?will it fit in my engine bay im not sure if my battery is bigger than the standard one here is a pic of my engine bay,
P.S. no big deal but do you still have the box for it by any chance? If its possible i can grab the uas pipe and hks filter off y ou and pay on t he first of of november (my funds enter my bank account on the wednesday). Can we say 200 for the lot including postage?
Delvance
Post by Delvance »
1 HKS super power flow kit to AMACHA!
This is EXACTLY what it will come with
The pod shell, the metal case that holds the filter down, screw that holds the metal case to the shell, 3 filters (1 triple layer, 2 dual layer), 4" metal tube adapter, 2 steel cable clamps, and you can have my dodgy heatshield that went with it if you want (hey it works :P ).
The picture shows a kit not for an fto and that kit has a few bits extra such as some bolts (which i can see is used for the air flow sensor on that particular car). My kit doesn't have those screws but you won't need it as you've got a gpx and there's no air flow meter, just the map sensor.
PM incoming.
Oh woops, forgot to say...sorry i don't have the box :(
Delvance
Post by Delvance »
$200 plus post is fine for the UAS pipe and HKS kit. The UAS pipe is direct fit and should fit in your engine. The battery clamp will slightly push against the pipe but i eventually fixed that by just shifting the battery over then using a cable tie to not let it slide to the left where the intake pipe was.
The UAS pipe is not direct fit though, as it has no fitting for the breather hose. You're going to need an oil catch tank or make a dodgy one yourself (which i did haha). The clamps off your stock intake pipe will then go onto the UAS pipe but i can supply one clamp for the throttle body.
akumi
Post by akumi »
Hey Amacha! Showo me your setup for the UAS pipe once u've installed it. I'm located in Sth Melbourne, which suburb are you located?
EZCONSOLE & EZMODCHIPS - We repair, upgrade and buy off Xbox 360, Wii, NDS, PS2 and PS3. Pickup & delivery services available. Xbox, Wii and NDS repair and opening tools available. Reasonable offers for non-working xbox 360 and Wii. Contact me for all oth
AMACHA
Post by AMACHA »
hey akumi yep no worries i wont be fitting for another couple of weeks i got uni exams atm so once t here done ill fit it asap im located in Thornbury thats near Northcote Fairfield about 10 min drive from RMIT Uni in the city.
akumi
Post by akumi »
nice! i used 2 work in northcote
bonker
Post by bonker »
Do you still have the exhaust ?.
akumi wrote:Hey Amacha! Showo me your setup for the UAS pipe once u've installed it. I'm located in Sth Melbourne, which suburb are you located?
I have the whole UAS intake and live and work in Bentleigh.
What times are you at Eplot, Akumi?
akumi
Post by akumi »
hi supplanter, i work from 8.30am till 7pm everyday mon to fri, sat is 11am to 3pm, it'll be great to see you coz it's been a while
Delvance
Post by Delvance »
bonker wrote:Do you still have the exhaust ?.
Sorry, car went into exhaust shop today and no one posted "i'll take it
" so i didn't get it removed.
