Brake Shudder
bduffman
Re: Brake Shudder
Post by bduffman »
94-97 non mivec have 256mm discs
97-00 non mivec have 256mm discs and 45.2mm height
94-97 mivecs have276mm discs
So the mivec ones in 4000 series are $179 standard and $199 slotted trade price
Re: Brake Shudder
Do a search guys :roll: :lol:
The going price for 4000's is about $330 a set! Slotted!
bduffman
Re: Brake Shudder
Post by bduffman »
How's that work if trade price is 200 each
Trade price was from autobarn so there buying them from dba at 200 each
Re: Brake Shudder
Clearly your trade price is BS :lol:
And that's slotted!
Re: Brake Shudder
One of many posts listing where to buy these and how much, plus a little useful information thrown in ;)
http://ftoaustralia.com/v3/viewtopic.php?f=1&t=21941
Kuran
Re: Brake Shudder
Post by Kuran »
I cannot for the life of me find any for $330!!
Re: Brake Shudder
Just found out that my front rotors are too small and havent been wearing the tops of the brake pads. f**king toowoomba and there imcompetency of getting the right parts.
Also the rotors on the back are they the same size as the front on a GPX, as the rear pads arent covering like a lot of the rotor like 3/4 of it.
Re: Brake Shudder
silverGPX wrote:Also the rotors on the back are they the same size as the front on a GPX, as the rear pads arent covering like a lot of the rotor like 3/4 of it.
Nope, but probably bigger than GR rears, someone else will confirm :)
Edit: I'd be reporting this to Dept Fair Trading / Mechanics organisations / NRMA if they're a member!
This is just pure incompetence!! Shut the f**kers down lol!
Re: Brake Shudder
Agreed ^ Downright dangerous.... all brakes places have massive public liability insurance too... maybe you could 'leverage' off that...
Oh & btw, all FTO rear discs are the same size.
Re: Brake Shudder
no i put the front rotors on myself but i didnt notice that it wasnt using all the pad. Do u reckon i can just move the front rotors to the rear and rears to the front?
Re: Brake Shudder
^^ haha, so you're to blame, someone slap this boys head :lol:
Here we were starting a manhunt on some poor Toowoomba mechanic :lol:
No I don't believe you can just swap the fronts to the rear, likely different size and offset. Ben will confirm :D
Re: Brake Shudder
lol, no you can't move them to the rear. The rears are different in a number of ways, size, offset etc. Forget about the rears.
You need to go buy a set of GPX 276mm rotors & new set of pads! Unless your comfortable grinding them flat on a belt grinder....
Shane001 wrote:Here we were starting a manhunt on some poor Toowoomba mechanic :lol:
bduffman
Re: Brake Shudder
Post by bduffman »
:facepalm:
Re: Brake Shudder
dooont make fun of me! :'( :P
Kuran
Re: Brake Shudder
Post by Kuran »
Still driving around with warped discs and ABS light on. Hope no-one stops within 100m in front of me :roll:
bduffman
Re: Brake Shudder
Post by bduffman »
try changing the pads first
mine used to shutter a lot but changed the pads and havent really had any issues since
bleed the brakes while your at it im out west next two days might give ya a message
Re: Brake Shudder
bduffman wrote:try changing the pads first
When changing pads you ALWAYS bleed the brakes. Its not optional.
bduffman
Re: Brake Shudder
Post by bduffman »
i know that but didnt know if he did so fidgued ill say it
Re: Brake Shudder
I8A4RE wrote:When changing pads you ALWAYS bleed the brakes. Its not optional.
BS :lol:
There's no technical reason why you have to bleed the brakes when you change pads, though yes it's probably not a bad idea if they haven't been done for a while, but for a street car probably more benefit from a full flush rather than just a bleed.
Re: Brake Shudder
BS :lol:
A mate I think you need to check again, do you know what bleeding is? Ask any mechanic and they will tell you HAVE to bleed the brakes when you change the pads. If I didn't bleed the brakes as an apprentice I would have had my ass handed to me because as soon as the customer left the workshop they would have plowed into the first thing that they came close too. I can t even imagine how spongy the brake pedal would feel if you didn't 8O
The technical reason: After you compress the piston in the caliper (to get the caliper over the new pads) you get air in the system when applying the brake pedal for the first couple of times.
No not all, brake fluid only needs to be replaced every 40,000 or so KM's (depending on type of brake fluid, car type, and usage). Doing a brake flush every time is just a waste of fluid.
