Brake Shudder
Kuran
Brake Shudder
Post by Kuran »
Hey guys,
When I apply the brakes there is a considerable amount of shudder coming through the pedal and there seems to be a bit of inconsistency. I've heard that machining the discs fixes this problem, any ideas?? I'd appreciate a quote on fixing this too if any of you guys have encountered the same thing. Cheers, Kuran
Re: Brake Shudder
Yeah your discs could be warped.
Re: Brake Shudder
Can you get slotted/cross-drilled rotors machined?
Re: Brake Shudder
Supplanter wrote:Can you get slotted/cross-drilled rotors machined?
Yep.
Kuran
Re: Brake Shudder
Post by Kuran »
how much do you rekon it'll set me back?
bduffman
Re: Brake Shudder
Post by bduffman »
get gpx calipers and master and get slotted rotors there not cheap
Look up dba rotors I need some to but got no money I can get them cost price though
Re: Brake Shudder
Kuran wrote:how much do you rekon it'll set me back?
A few years ago I got the stock rotors machined for around $25 I think, shouldn't be much more than that now.
Re: Brake Shudder
Anyone know the minimum diameter on the discs?
Re: Brake Shudder
Mate I had this problem really bad when I bought my beast.
I ended up replacing the rotors and pads..
Put slotted RDAs and Bendix CRTs on.
Not too expensive and stops like a dream now :)
Kuran
Re: Brake Shudder
Post by Kuran »
Thanks for the advice guys, appreciate it. I'll look into it over the weekend
spency
Re: Brake Shudder
Post by spency »
Lol. I had rotors machined, brakes bled and new pads installed for a carton of piss by a mate who works at beaurepairs. So on the mainland, should only cost $50?
Re: Brake Shudder
silverGPX wrote:Anyone know the minimum diameter on the discs?
276mm - GPX & GPvR.
Kuran
Re: Brake Shudder
Post by Kuran »
I spent every last cent i have on my fto so until saturday I can't even afford petrol :D. I'll have some big $$ though when i sell my other car
Re: Brake Shudder
The RDA slotted rotors are well priced and will stop that problem occurring unless you are crazy on the brakes. Unfortunately, stock GR/GPX rotors warp fairly easily. If you get them machined, theyll be OK, but if you are heavy on the brakes, theyll just warp on you again. I think the RDA's are around $220 for the fronts from memory and are well worh the outlay (better braking and less chance of warping). You shouldnt need to replace the rears as they are unlikely to warp (they do a lot less work when braking).
    Re: Brake Shudder
    I got my rda slotted rotors for 180 I think :) just shop around
    Re: Brake Shudder
    even better.....
      Kuran
      Re: Brake Shudder
      Post by Kuran »
      Are the standard DBA425 rotors any good (in terms of long life and not warping and things)? I don't brake that hard unless i'm having play time :twisted: Would they be worth my money though or am i better off paying 100 bucks more for slotted?
      Re: Brake Shudder
      Slotted foe the win.
      It's better to have them there when you need them not wish that you had put them on when your breads fall away.
      Re: Brake Shudder
      Avoid the 400 series full stop. They're just standard rotors slotted or drilled to order. You want decent ones, the 4000 series is the only way to go.
      Kuran
      Re: Brake Shudder
      Post by Kuran »
      DBA's website says the 4000sl's are 300 bucks each 8O
