Redlining at 6k rpm instead of 8k rpm..
- Storm
Re: Redlining at 6k rpm instead of 8k rpm..
Just to be boring and get back on track for a moment, remember the temp sensor for the ECU is a different one from the dash sensor and if it is goosed it can trick the ECU into believing the car is colder than it is so restricting the revs as well as overfuelling the engine.
LOLbass_twitch wrote:Remind me never to buy your carrenzkuken1 wrote:i get to 70ish in firstlol
No wonder you got gearbox problems! Your poor torque converter...
- renzkuken1
yeah haha i always do it love my size of car it slots the smallest spotsbduffman wrote:Rez do you own a corolla as well or did own one, ever been apart of src ,
I red line mine all the time mainly cause I beat people off the mark to steal there lane =)
and im not planning on selling aha i would get a new engine and convert to turbo manual conversion before i think about a new car. then salary sacrifice a 370z
Have my fto as showroom car and keep it garaged after that.
- renzkuken1
How can i fix this? lolStorm wrote:Just to be boring and get back on track for a moment, remember the temp sensor for the ECU is a different one from the dash sensor and if it is goosed it can trick the ECU into believing the car is colder than it is so restricting the revs as well as overfuelling the engine.
- Storm
A new one over here is around a tenner (dont know what that is in dollars) so you can just replace it or theres a test you can do to check its resistance as it warms up but I dont have access to any manuals at the mo so someone who coes might hopefully look it up and tell you.renzkuken1 wrote:How can i fix this? lolStorm wrote:Just to be boring and get back on track for a moment, remember the temp sensor for the ECU is a different one from the dash sensor and if it is goosed it can trick the ECU into believing the car is colder than it is so restricting the revs as well as overfuelling the engine.
- renzkuken1
Storm wrote:A new one over here is around a tenner (dont know what that is in dollars) so you can just replace it or theres a test you can do to check its resistance as it warms up but I dont have access to any manuals at the mo so someone who coes might hopefully look it up and tell you.renzkuken1 wrote:How can i fix this? lolStorm wrote:Just to be boring and get back on track for a moment, remember the temp sensor for the ECU is a different one from the dash sensor and if it is goosed it can trick the ECU into believing the car is colder than it is so restricting the revs as well as overfuelling the engine.
