Redlining at 6k rpm instead of 8k rpm..
renzkuken1
Post by renzkuken1 »
I just drove it to the shops and it redlined at 6k rpm in first instead of 8k rpm wtf is wrong with it? Is it the engine or the gear box? :o
gpx000
Re: Redlining at 6k rpm instead of 8k rpm..
Post by gpx000 »
yeah that happened to me yesterday and the day before.
the car got a full service and tune up, going to see if it still does it.
Dras
Post by Dras »
Sounds like your alternator is knackered.
renzkuken1
gpx000 wrote:yeah that happened to me yesterday and the day before.
Let me know mate,i would really appreciate it :)
Hope it won't cost much.
if the engine is not at normal operating temp it wont let it rev past 6k as a safety feture
renzkuken1
so it will redline it at 6k revz instead? wow i hope that's it. I don't see why i twould be hot though cause it wasnt that hot a day and i just started the car..
evoman
Post by evoman »
renzkuken1 wrote:so it will redline it at 6k revz instead? wow i hope that's it. I don't see why i twould be hot though cause it wasnt that hot a day and i just started the car..
What vipfto meant was that if the car isn't warm enough (ie not up to full operating temperature), it will rev limit you at 6k to protect the engine. Probably shouldn't be revving your car that hard so soon after starting it without letting it warm up properly.
renzkuken1
ahh cheers. I get it :)
thanks for that.
The FTO has a progressive rev limiter... as the car gets warmer, it revs higher... at cold it cuts you out around 6-6.5, then as it warms up it lets you do more...
P.S. just because it lets you rev to 8250, doesn't mean the car is actually ready for it... :p
Gholdwayne
Post by Gholdwayne »
I always give it a good 10mins of granny drive when the engine is cold. That happened to me before.
If it continues when the car is warm, then what Dras said... Could be the alternator...
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
Redlining just 'on your way to the shops?' :facepalm2:
spency
Post by spency »
Bennoz wrote:Redlining just 'on your way to the shops?' :facepalm2:
Judgement.
I do it. I live 15km from shops in the bush. Sealed roads on rural areas are fun. Enough said.
renzkuken1
I have an intersection leaving the raaf base which requires me to slot into gaps that the normal corolla wouldn't be able to :lol:
so yes i get just before 8000rpm before shifting to second :)
The only chance I get to redline my car is getting onto the M7 at 100kph.
2 gears & a whole bunch of wheelspin & its all over in a few seconds :(
And that's not a euphemism ^ :lol:
renzkuken1
i get to 70ish in first :lol:
renzkuken1 wrote:i get to 70ish in first :lol:
Remind me never to buy your car ;) lol
spency
Post by spency »
Bennoz wrote:The only chance I get to redline my car is getting onto the M7 at 100kph.
Not the only thing over in a few seconds ;)
Touché, dad :lol:
bduffman
Post by bduffman »
Rez do you own a corolla as well or did own one, ever been apart of src ,
I red line mine all the time mainly cause I beat people off the mark to steal there lane =)
