FS: Full 2.5" exhaust system. Back for sale again (pics
FtoSam
Post by FtoSam »
Okay now with turbo engine im prob going to have to upgrade to 3 inch. Bugger.. only just got my 2.5" system installed... argh.. oh well if i get my new one this will be up for sale. Just wanna know what i could get for it.
It comprimises of:
2.5 inch Piping from extractors through to Quality High-Flow CAT, with all restrictors removed and then splits at the rear wheels to go out two 4 Inch Cannons.
This entire setup cost me:
Piping: $250
High-Flow CAT - $350
Y Piece - $100 i think
Cannons $145 ea.
So i think it cost around $850 for the whole setup... not including labour. So I was thinking maybe around $500... I only had most of this done about 3 months ago.. maybe less...but it sounds awesome and deffinately flows better than standard.
Im no mechanic but i assum this will just pull down out of mine go straight back up into another FTO.
I'm located in qld.. not sure how much postage would be.. wouldnt think it would be cheap.
Pics:
Basically, what is for sale is everything from the point where the heat wrap ends, and the shiny bit starts... right through to the tips.
EURO
Post by EURO »
I would be interested in buying the high flow cat....pm me..
Hobbsie
Post by Hobbsie »
mate 2.5" will not restrict you at all unless your pumping out 300+kws
FtoSam
Post by FtoSam »
As far as i knew a bigger pipe would allow the turbo to spool fast or something?
Hobbsie
Post by Hobbsie »
sorry 3" is fine actually its what i have, got a bit confused :P
although 2.5" probably wouldn't be a noticeable difference with the kind of power you would be putting out
as for spooling faster the piping and catback wont make a difference to that, the down pipe and/or front pipe are what effects your turbo spool since exhaust is what powers your turbo so the bigger pipes the faster it spools.
khunjeng
Post by khunjeng »
Hobbsie wrote:as for spooling faster the piping and catback wont make a difference to that, the down pipe and/or front pipe are what effects your turbo spool since exhaust is what powers your turbo so the bigger pipes the faster it spools.
lol, thats a crock mate.
All else being equal, The amount of work that can be done across an exhaust turbine is determined by the pressure differential at the inlet and outlet. Pressure is heat, heat is pressure, the ideal gas law.
Raising the inlet pressure is possible, but tough. Lowering the outlet pressure is easy - just bolt on a bigger, free flowing exhaust. The dump pipe is really just an extention to the zorst but does not act is isolation..
By lowering the outlet pressure the exhaust gas can expand more, and do more work. That increased work spools the turbo faster and in many cases gives some decent output gains. 15-30rwkw has been seen and is common.
mr-charisma
Post by mr-charisma »
pm sent
FtoSam
Post by FtoSam »
Awesome... Mr-Charisma has it
mr-charisma
Sweet :)
Good buy :wink:
FtoSam
Post by FtoSam »
Still up for sale people.
$500 for the lot. Im getting it taken off and my new system put on at Right Price Exhaust at Springwood.
Keep in mind you have to get the hole cut in your rear bumper. I just got a body shop to do it. $20... Not bad. Also a couple of hangers for the 2nd pipe... no biggie...
Cmon people... Some dual exhaust lovin available right here... Most of this system has only been on a few months. (only the cannons are 9 months old, the rest only about 3-4)
mxysxy
Post by mxysxy »
any chance Ben can bring this setup in the car to VIC on the way to Autosalon? :o
FtoSam
Post by FtoSam »
If he picks it up from brisbane??? lol
mxysxy
Post by mxysxy »
lol No.
FtoSam
Post by FtoSam »
ROFL :lol:
bigpitty1
Post by bigpitty1 »
how much for the CAT and the piping all the way up to the Y piece. not including the Y piece.
FtoSam
Post by FtoSam »
Will not seperate.
Anyone wanna play spot the air filter???
khunjeng
Post by khunjeng »
how loud is it?
FtoSam
Post by FtoSam »
Reasonably loud. If too loud all you need is a restrictor put in.
