Which tyres?
Which tyres?
I'm close to getting a full set of new tyres for the FTO and was wondering what are the best to go with. Looking for real handling performance.
Oh and this is mildly off topic in this section, but I think the LED behind my 'D' symbol for my transmission has died, how hard is it to replace that?
- Delvance
BF Goodrich G-force sports is on my corolla atm, really really nice tyres. I seriously cannot fault those tyres at all. FTO has some Yokohama A.Drive R1s on it, also nice - grippy, predictable, low noise, comfy but they are soft so probably won't wear well.
Listing some preferences would make it easier ? Are you after grip only, all rounder etc.
Depends on how much you wanna spend, the best you can get is Michellin Pilot Sport / dunlop sport maxx ... best handling & grip but very expensive $300-$500 a tyre depends on sizeoodLes wrote:Really after a good handling tyre, tons of grip through the bends.
- FTO338
If you want good price and decent performance, then try the Hankook range. Hammann, the Euro exotic tuners had chosen them for all their modified Ferrari, Lambo..etc.
- droidy
- droidy
- khunjeng
why would he want semis?droidy wrote:bridgestone semi slicksseriously put 225's on the front! Oodles you're in Albury? My mate Tony at Beurepairs in Wodonga might be able to hook you up with a good deal. You'll have to be quick though cause he's quiting that job real soon. I got get some 225 semi slicks off him before then myself!
for his FTO..Hancook 104s would be fine.
Gotta be careful tyre compounds differ from region to region to account for different conditions.droidy wrote:btw check out the customer reviews on tirerack.com They go psycho on the track work/racing in California. So you'll get soe good feedback on that site. I like how you check how different wheels look on you're car on there too. No fto thoughDoes have lancer though
I'd recommend plenty, depends on the size/ budget
Toyo Proxes T1-R
Kumho Ecsta MX
Potenza GIIIs
Direzza DZ101s
Continentals
- Delvance
One of the grippiest tires i've felt would be Bridgestone Potenza Re050s, barring semi slicks. I would definitely consider them if i were after high grip. The BF Goodrich G-force sports are really really grippy too, i'm pretty sure they won the Motor small tire test in 05.
Havn't experienced any of the above mentioned tires so can't comment on those.
At one stage i was very close to getting Toyo Proxes T1-R cause i know it's good, Kumho Ecsta have very good grip ... prove by doing burnouts LOL, Potenza GIIIs is very good for corner but grips on striaght is not as good as i expected, michelin pilot sport is still the best one i've use so far
Again ... it all comes down to a price issue.
- khunjeng
led
And to answer your other question, the led is actually a globe that runs that while panel (D,P,N etc). To get at it try this guide:
http://www.completefto.com.au/FTO_showcontent.asp?aid=343
- spetz
Go semi's
If you shop around they're not that expensive
I have those A-drives and they aren't bad but not overly grippy compared to the Bridgestone S-02's I had/have but they are more expensive than semi slicks
Also, falken FK-452 are grippier than A drivers and cost less I think
C-drives apparently are quite good though
