Which Heavy Clutch should i buy?
- FtoSam
Okay, As most of you know my car is now turbo.. yay!!!
So its time to upgrade the factory clutch. First of all im wanting to be putting down figures around 150kw atw next tuesday when it gets dyno'd. however after a few little mods i want to get up around 200 or so.
So I have two options:
1. Get a new clutch
2. Get current clutch strengthened by Direct Clutch in bris ($800)
I prefer option 1. as i dont want to be without my car for 4-5 days.
I also know some guys up the chain at autobarn, so would prefer Exceedy or something else they can supply as i get very good prices. like really good.
Now if the standard clutch is 400kg Clamping Pressure. and im trying to increase my power by 100% then i guess i need around 800Kg?? (or doesnt it work that way?) I do want to be able to drive it around the city but also let loose at the circuit. I was advised by one bloke that a cushioned brass button clutch would be suitable if i found one of the right pressure.
I wouldnt mind spending around $700 or so on it either. But i want it to be able the 200-220kw i plan to extract out of my car by the end of the year.
Any help would be awesome.
1. Get a new clutch
- FtoSam
But i dont want to be without my car for days. I need it very regularly. one day i can manage 2 would be quite hard and 3 near impossible. Direct clutch said they would need 3 days work on the clutch. not including taking it out and putting it back in again.
I really really really dont want to do that option unless its absolutely the only way.
Hmm. A twin-plate clutch would sort you out but I'm unaware of any that are made for the FTO.
Take a look at the Exedy line:
http://www.exedy.com.au/catalogue-detai ... d=38999656
There's a couple of heavy duty ones, don't know if they'd hold up with the additional torque loading from your turbo (should be alright under 150kw, probably not at 200kw). Treat it easy for now, and you should be ok.
BTW those places should be able to modify an aftermarket clutch for a bit more holding power if you really need.
- FtoSam
- FtoSam
- khunjeng
I have any in my line. Twin plate cushion button. Which really makes it a mild twin plate.EURO wrote:I nearly did but got talked out of it - said was very difficult to use and painful in any kind of congestive trafficJono wrote:has anyone had a exedy cushion button clutch here before?
Very hard to drive in heavy traffic but u get used to it.
Grips like a mofo...great for launches. Can be served also.
Not suitablle for cars running low HP...no point.
- khunjeng
- spetz
I've driven a lancer with FTO motor/gearbox and button clutch
Seriously would not recommend this if it is a street driven car
Even though it was drivable (ie, you could still get around) it was just stupidly stiff to press and the amounts of grip the clutch had was unbelievable... smooth changes were a thing of the past!
