Where to connect the ground cable
mxysxy
Post by mxysxy »
The cable that comes out of the starter motor goes all the way up between radiator and engine.
About the radiator top height, grounding comes out of this cable and screwed to the engine block.
Can someone please post a pic of where does this grounding screws to?
I am not sure about the location
Thanks
[img]http://www.smyrnaie.com/SeatCovers/FTO/ftobanner.jpg[/img]
khunjeng
Re: Where to connect the ground cable
Post by khunjeng »
mxysxy wrote:The cable that comes out of the starter motor goes all the way up between radiator and engine.
Thanks
probably something metal if its the earth strap. just earth it on the chasis somehwre. I will look tomorrow if u like.
mxysxy
Post by mxysxy »
khunjeng wrote:probably something metal if its the earth strap. just earth it on the chasis somehwre. I will look tomorrow if u like.
Thanks Chris,
Will be great if you can locate the exact place
khunjeng
Post by khunjeng »
ok the Positive runs to the battery
and the earth runs up under the airbox. It must just be bolted to the body under there somewhere. Looks like some otehr cables going there two..i.e. the earth from the battery.
Have a look there.
