More auto gear box problems
Digital_Import
Post by Digital_Import »
Im having my crank angle sensor changed at the moment when I noticed that when i shift into drive or sports mode the D letter does not illuminate on the dash, I have no idea what this means. Anyone have any idea? Everything else comes up, P, R, N.
Bulb
Could be something as simple as the bulb.....
    Sparhawk
    Post by Sparhawk »
    Agree with dstocks. Had a similar prob in the Magna I had. The "D" didnt light up on the dash. Was the bulb. Makes sense considering D is the one that is on most too...
    Checking the bulb is easy. Pulling the dash out is just a matter of 2 screws and a few plugs on the surround. Then 4 screws on the cluster and it just pulls out. The bulbs are just held in little black twist in holders. Thats one thing I have to hand to Mitsubishi, every one I have owned has been easy to get the dash out :D
    [color=blue]Death is life's way of telling you - you're fired.[/color]
    Oh Bugger, my sig block pic has dropped off the host ;(
    TCGPX
    Post by TCGPX »
    I'm pretty sure the D goes out when you shift to tiptronic too.
    TCGPX wrote:I'm pretty sure the D goes out when you shift to tiptronic too.
    Seconded.
