Keyless locking doesn't work?? help??
Rauny
Post by Rauny »
Hi guy's, My car won't lock or open on one side when i press the button? Any ideas? thanks
BorepYano
Post by BorepYano »
check the wiring and then the motor which is behind the metal frame when u take the interior door panel off.
http://www.ftoaustralia.com/modules.php ... al+locking
use the search. lol (i kept getting told to do that when i started here... who am i kidding i still do lol)
it's apparently a common problem, so most of it should be covered already :)
good luck
khunjeng
Post by khunjeng »
it will be the solinoid/motor. Follow the links and buy a unit from Jaycar for like $15.
Then follow the links for install. I did mine today, works great and takes about 1hr to complete.
Check which side isn't working and fix that...but if your in the mood do both and its will be right for ever after you have finished.
