Oh my God my dash is dead
All the lights on my dash have dies i cant drive around in the dark anymore because i cant see what speed im going. Nothing lights up anymore including the gearbox and aircon. HELPPPPPPP
- FtoSam
Check fuses first of all
then check your dimmer switch.. maybe try shorting the connection to see if they light up.
then take out the dash console and look for anything obvious.
then look behind dash for loose wires
could also be in a relay somewhere.
my 2c
my 2c
Here's a description of the fuses, courtesy of a post from dstocks. I'm guessing it's the one I've highlighted?:
FUSE BOXES
Inside box
1-10A Horn
2-10A Heater Relay
3-15A Cigarette Lighter
4-10A Automatic Transmission
5-10A Active Side Mirror
6-20A Sunroof
7-30A Defogger
8-10A meter Panel
9-15A Wiper
10-30A Heater
11-15A Door Lock
12-10A Traction Control
13-10A backup Lamp
14-10A Turn Signal Lamp
15 Spare Fuse
Engine Bay
1-10A Tail Lamp
2-10A High Beam
3-10A Air Conditioner
4-10A Room Lamp
5-15A Radio
6-15A Stop Lamp
7-10A Hazard Lamp
8-15A Fog Lamp
9-30A Condeser Fan
Fusible Link
10-30A Power Window
11-50A ABS
12-40A Ignition Key
13-30A Radiator Fan
14-40A Lamp
15-20A MPI
16-80A Alternator
FUSE BOXES
Inside box
1-10A Horn
2-10A Heater Relay
6-20A Sunroof
7-30A Defogger
8-10A meter Panel
9-15A Wiper
10-30A Heater
11-15A Door Lock
13-10A backup Lamp
15 Spare Fuse
Engine Bay
1-10A Tail Lamp
2-10A High Beam
4-10A Room Lamp
5-15A Radio
6-15A Stop Lamp
7-10A Hazard Lamp
8-15A Fog Lamp
9-30A Condeser Fan
Fusible Link
10-30A Power Window
11-50A ABS
12-40A Ignition Key
13-30A Radiator Fan
14-40A Lamp
15-20A MPI
16-80A Alternator
- khunjeng
- boarsai
- boarsai
Sounds like something I'd use... if I'd known about it prior to getting on my back and delving under the dash.kid_dynamite wrote:Or if you can't be bothered to pull them out, buy a test light. You can check all the fuses in about 15 secondsjonowong wrote:the fuse is clear in the middle... if the piece of metal is snapped, the fuse is fucked
A fool and his money are soon parted.
Probably why I'm forever broke
- boarsai
- kazbah
- National Secretary
Resurrection time... I've pulled all the fuses in both the footwell (found a strange toggle switch under there *scratches head*) and the engine bay, still now lights. Oh and I've also mucked around with the dimmer switch... Any other suggestions, and I hope to god you dont tell me to pull the dash apart!!
Teh Ban Queen!
- kazbah
