Installing Oil Pressure Guage.
- FtoSam
Righto. I've installed this guage about a month ago..
Now i've finally decided to get off my ass and get it working
Guage is in the center top bit (replacing volt guage)
I have the power hooked up for it. But where does the sender unit go? In the block i assume...
Has anyone done this?
help?
help?
Re: Installing Oil Pressure Guage.
Easiest is to use a sandwich plate adaptor at the oil filter.FtoSam wrote:Righto. I've installed this guage about a month ago..
help?
Or as you said, tap a fitting into the block.
- FtoSam
- FtoSam
Quick mention Sam - it sounds like Jono is talking about installing a mechanical gauge, whilst I'm referring to an electrical one.
A mech one will require a brass tee fitting, but an electrical one (I'm assuming you have an electrical one because you send sender) - needs a thread be tapped into the block and then you just screw the sender in (after using some teflon sealant).
/edit. Here's some examples of installaiton from the Autometer website:
Mechanical Pressure Gauges:
http://www.autometer.com/download_instruction/318j.pdf
http://www.autometer.com/download_instruction/247e.pdf
Electrical Pressure Gauges:
http://www.autometer.com/download_instruction/0621B.pdf
http://www.autometer.com/download_instruction/1079A.pdf
- FtoSam
- FtoSam
- FtoSam
