shock touching tyre
rocketride
shock touching tyre
Post by rocketride »
Help
Need some advice changed my shocks (KYB) and springs today and the driver side wheel is now just resting againt the shock at the bottom of the bottom spring pan????? The passanger side is fine
Could i have put the top mount on the wrong way? DOH? Is there a way of telling which way the top mounts go? As in which of the three pins at the front etc?
Also do the rear have to go a certain way round, ill check those aswell
The hole in the shock is aligned with the hole in the spring pan so i know its not that :wink:
Or is it tracking?
Cheers
Yep, the top 3 pins can only go in one way. Plenty of info in here:
http://www.ftoaustralia.com/modules.php ... pic&t=8761
rocketride
I cant see where it says about which way it goes? Are the pins numbered?
cheers
