major & minor service
- tadasu
hi, just wanna know what major and minor services comprised of? gonna send my car for service, but not sure which 1 to choose (87,000km , no service history as the car was imported from jap late last year...). thanks.
Minor:
Oil change
Oil filter change
Air filter change
Fuel filter change
Major:
Oil change
Oil filter change
Air filter change
Fuel filter change
Spark Plug change
Intake manifold gasket
100k:
Oil change
Oil filter change
Air filter change
Fuel filter change
Spark Plug change
Timing Belt change
Water Pump change
Cam Seal change
In a nutshell. Plenty more information on the site if you search for it.
Oil change
Oil filter change
Air filter change
Fuel filter change
Major:
Oil change
Oil filter change
Air filter change
Fuel filter change
Spark Plug change
100k:
Oil change
Oil filter change
Air filter change
Fuel filter change
Spark Plug change
Timing Belt change
Water Pump change
Cam Seal change
- SilverFluids
If it's approaching the 100xxx mark then you'll want a major service that will replace spark plugs and change the timing belt (if this snaps then bye bye engine). Whilst the manifold is off they can also check the water pump to ensure it's not leaking and replace as neccessary. They'll also do the minor service in that they'll ensure everything looks as it should, change fluids, filters, etc.
Last major service of mine was close to $2k but I had a lot done, so I'd be looking at around $1k for yourself. If you have a MiVEC GPX then the generic timing belts don't fit and you'll generally need a Mitsu one for around $250 :S (a lot more than $60!). A minor service would only cost around $200 with the things already mentioned, but as I said, the car is nearing the 100k mark with no service history so a major service would be the way to go to ensure you don't have to spend $4k+ down the track
- SilverFluids
I'm currently doing mine. Car sitting on 94k, been serviced every 5k since in got it about a rear ago. So far, the parts cost are as follows;
Oil - $32 5L (penzoil 10W40)
Oil filter - $10
Air filter - mine is relatively new
Fuel filter - $20
Spark Plug - unsure which to buy yet
Intake manifold gasket - ? not sure of cost
Timing Belt - $120
Water Pump - $100
Cam Seal - ? not sure of cost
Oxy sensor - $80
So far it ain't too bad I guess. With labour, it suppose it'll be a bit over the 1k mark. My mechanic said it'll cost me about $600 for labout
Oil filter - $10
Fuel filter - $20
Timing Belt - $120
Water Pump - $100
Oxy sensor - $80
- Delvance
I'm also looking to do a 100k service for my car, anyone want to provide brand and part numbers for some items please ? (I tried searching but couldn't come up with much
Tming belt (the gates branded one, do any stores stock them ?)
Fuel filter ? Or do you peeps just order a genuine one from mitsu
water pump
cam seal
Oxy sensor
Any help appreciated, thanks!
water pump
cam seal
Oxy sensor
Gates belt is sold by Repco
Fuel Filter:
http://www.ftoaustralia.com/modules.php ... 49&start=0
Intake Manifold Gasket:
http://www.ftoaustralia.com/modules.php ... rpw+gasket
Water Pump:
http://www.ftoaustralia.com/modules.php ... water+pump
Cam Seal:
I'll have to look this up on CAPS for you - will be a Mitsi part.
Oxy Sensor:
http://www.ftoaustralia.com/modules.php ... ght=oxygen
When you search for something specific - you have to use the word 'and' in your search. Ie if looking for a water pump, search for 'water and pump' otherwise if you just put 'water pump' it will return results for every thread that has the word water or pump in it. When you use 'and' it returns results for threads that contain both the words water & pump
- SilverFluids
- lwrida
Just rang up Maytech for my 100k service guy goes I'm lookin at $1300
too much ? considering he won't do the Oil, oil filter, fuel filter, air filter and sparks which was done by them a couple weeks back
aithnÃÂm thú grá sÃÂ, aithnÃÂm thú grá sÃÂ, aithnÃÂm thú sibh sin mé bualadh craicinn sibh... FTO GPX 95' táirgàtuilÃÂ
[img]http://img148.imageshack.us/img148/8306/banner2ae0.jpg[/img]
- lwrida
- Delvance
Its the gap that is 0.4mm not the core size, they last just as long - I run the Densos.Delvance wrote:How about the Denso Iridiums ? I had them in another car and they were pretty good. You got to replace them sooner than other irdiums/plats though as the core is 0.4 The ones for a gpx are ik22 not sure for gr.
- Delvance
Oohh ok, i always thought it was the electrode diameter. The ones linked below say the diameter of the electrode is 0.4mm o.0
http://cgi.ebay.com.au/New-Denso-Iridiu ... dZViewItem
I think they can be had cheaper even on ebay.com (American ebay site).
