heres a hard one, im dump founded :(
- kermut
ok so today i did a compression test and all the cylinders where fine except the spark plugs looked like water got to them and two were bent. any ideas why this is happening?
- kermut
Got any crank case pressure readings?kermut wrote:could the blown head gasket fix my boost problem i was having
when it was turbo charged. cause i could hear the turbo but felt no boost and one time i remember when i went over a bump boost came from nowhere hummzzz weird :O.....i was thinking the bent spark plug could be a warped rod ???
- kermut
