1995 HJ galant 6a12 power problems
stimpy
Post by stimpy »
i just bought a 1995 galant 6a12 (non mivec) and when it gets past 3000rpm
it revs but with barely any acceleration ...it has veritable length intake ..is that it?
oldie
Post by oldie »
If the engine is increasing in revs but the car is not increasing in speed the problem is likeely to be a slipping clutch.
Check for free travel at the clutch fork, if there is some the clutch is worn out, if you brought it from a car yard it may be covered by warranty :?
FtoSam
Post by FtoSam »
Turbo??? If so then that would be the clutch. As boost is kicking in around then (3krpm)
My std clutch dies at 3krpm at FOT.
If you lightly accelerate past 3,000rpm does it still do it? or is it only under FOT (Full Open Throttle)
stimpy
turbo
Post by stimpy »
its not turbo ..i'll check the clutch... already tried the air cleaner and the fuel filter
check the cat.
stimpy
spark plugs
Post by stimpy »
put new spark plugs in with no change
stimpy
cat
Post by stimpy »
took the cat off and held it into the sun looks to be fine
stimpy
ecu
Post by stimpy »
put in jap spec ecu lots more power but there's still something wrong.. it goes alright with lite throttle but die's with full throttle
Checked the clutch? Any probs getting it into gear?
stimpy
clutch
Post by stimpy »
clutch is heavy and sometimes the gears are crunchy
As Oldie mentioned above, it sounds like your clutch is worn out. If you have trouble getting it into gear & it wont pull past 3000rpm, the I'd garountee thats what it is. Do you also get a funky burning smell when you try & get it to go past 3000rpm?
FUS30N
Post by FUS30N »
hey mate,
where did you get the jap spec ecu???
I am after one for my HJ galant??
stimpy
ecu + clutch
Post by stimpy »
i got the ecu of "trademe" its like new zealand ebay cost $50
it fells like it could be the clutch
FUS30N
Post by FUS30N »
Mad!!, ECU is tuned for 100ron :D
