hey guys ,,,about D2 again , please come in , i need your help
yellowftogpx
Post by yellowftogpx »
i just contacted with the D2 seller from Ebay..they can provide me the coilover set with specified spring rate i want ..what do u guys recon ? 6kg on front and 4kg on rear ? need u guys' opinion ..thank you !!!!!!!!!!
SG
Post by SG »
apparently Tien SS are 5kg front and 4kg rear for the lancer/fto... and that is wrong! (for the fto)... need a heavier spring rate at the front... because thats what ive got on atm.. and theres just understeer compared to stock. When you turn in (when i had the car with stock susp.) I could turn as sharp as i liked (neutral throttle pos.) with no understeer, and when you lift off u get a bit of oversteer which was perfect. Now with the Tein SS.. even though the car sits lower... theres just understeer when turning in (neutral throttle pos. or lifting off)... and its anoying as.
Adjusting the stiffness of the dampers at the front compared to rear had no effect... full stiff front and full soft rear and it had basically the same effect as full stiff all round.
sorry ranted on a bit. need > 5kg on the front.
why do you think 6kg is good?
yellowftogpx
why do you think 6kg is good?[/quote]
i got this from here :roll: one of the topics about D2 in this forum...someone said that 6/4 would be good for daily use..
SG
Post by SG »
ah right. yeah i really dunno
get 6kg and let me know how it goes :)
wonder what the stock is :?
Stock is 2.6kg on the front & 1.6kg on the rear. 6 & 4 would be good for a sporty set up.
yellowftogpx
Bennoz wrote:Stock is 2.6kg on the front & 1.6kg on the rear. 6 & 4 would be good for a sporty set up.
cool ..thanks mate!
Delvance
Post by Delvance »
yellowftogpx wrote:why do you think 6kg is good?
i got this from here :roll: one of the topics about D2 in this forum...someone said that 6/4 would be good for daily use..[/quote]
Pretty sure i was the one that said 6/4 combo. Yeah should be good for daily sporty driving. Get a front strut as well if you don't have one already, it does help.
jonowong
Post by jonowong »
how do you guys put up with rougher?! im getting the sh*ts with my stock stuff + poly
Delvance
Post by Delvance »
Lol, i got used to my hard suspension after 2 weeks. I don't feel it anymore except for medium to bad bumps. Can't have everything!
yellowftogpx
anyone tried ? 6/4 with their suspension ?
