rocker cover painting
- tintin
i have read the post on how to paint the gpx rocker cover thats no prob but i have used back to black on the cover witch has silicone in it how do get that off because paint dosnt like going on to that
coilovers!! gaurenteed to make boobs bounce
- mr-charisma
First thing I'd probably try would be scrubbing it using one of those scratchy yellow & green washing up sponges, I wouldn't use anything harsher than that or some fine wet & dry sandpaper
otherwise you could try using Turps / Metho or go down to your local Supercheap or something & ask if they have any solvent for removing silicone ... but make sure that you give it a scrub in soapy water afterwards if you try those.
- BorepYano
use solvent as a last resort.mr-charisma wrote:...you could try using Turps / Metho or go down to your local Supercheap or something & ask if they have any solvent for removing silicone ...
cos u use the solvent to clean the original stuff off, u'll still have to scrub it heaps cos of the grooves and what not.
then u wash it with warm soapy water *flash back to yr8 home economic class* to wash the sovent off. u still have to scrub cos of the grooves
then u have to scrub with clean water a few times to make sure everythign is off
and if u've screwed up anywhere along the way at best u'll get bubbles in your paint when it dries, worst case it happens 2 days after lol
then u gotta go through the whole thing again and again.
can u just sand it off with some 300grit wet and dry?
- mr-charisma
- FtoSam
- mr-charisma
- FtoSam
- FtoSam
Bahahah... thats nothing... check out the vid http://www.youtube.com/watch?v=Cr-EHITrjSc... it says it better..
- BorepYano
still think i should've been the last photo at the end of "i'm too sexy for my shirt" bit lolFtoSam wrote:Bahahah... thats nothing... check out the vid http://www.youtube.com/watch?v=Cr-EHITrjSc... it says it better..
and we r getting off topic here guys. shame on u sam and ben lol
