nicholas wrote:Okay, so. My tacho hasn't worked since I got the car, but now it's starting to get to me.
Can someone point me to a DIY guide where I can pull the tacho out and look behind it? I'm not sure what I'll do then... just stare at the wiring and will it to work?
I've got an idea that it might be the ignition sensor (from my searching through the forum) but have no idea what this means... can I buy one and just plug it in somewhere, or what?
Help? Cheers guys
There are 2 screws holding the outer cover for speedo/rev unit,
take them off and pull the plastic cover out,
4 more screw holds the speedo unit, take them off and pull the unit straight out.
Then you can open the unit, however, you cant do much about it as there is no cables there, just a wiring board.
You probably need to get a new replacement unit.
I do have a manual unit for sale as well as the seat covers
