i found out how many teeth the standerd fly whel has
tintin
Post by tintin »
as the title says i found out how many teeth the standerd fly wheel has its 110 and i will let you all no if fadanza has 1 for the fto :)
hears a like to there stie :)
http://www.fidanza.com/default.aspx
coilovers!! gaurenteed to make boobs bounce :)
You can actually heat the ring gear up on the flywheel & actually remove it & transfer it to another flywheel.
