need slave cylinder, any alternative from other car makes?
giez26
Post by giez26 »
hi guys, my slave cylinder just died, does anyone noe where to get one? and also other alternatives like from other car makes whichwould fit?
thanks
onnzo
Post by onnzo »
What do you mean by died? Get it reconditioned.
giez26
Post by giez26 »
i'm in nsw, where can i get it reconditioned? its leaking now, and mechanic says to get replacement, but its hard to find this slave cylinder.
onnzo
Post by onnzo »
look up your local brake and clutch store and give em a call. not abs or midas, thet will just send it off to a specialist. in the yellow pages they should say they recondition parts. it is most likely the seals if it is leakIng, which will cost you under $50 for a seal kit. they will find one to suit.
giez26
Post by giez26 »
thanks for the tip onnzo...
giez26
no recondition parts
Post by giez26 »
i've called n sourced, but no luck on reconditioning. does anyone noe of a similar slave cylinder to the ftos's? maybe a lancer model? evo? urgent! thanks
oldie
slave cyl
Post by oldie »
Try calling Bernie's Brakes in Dandenong Vic. (03 9792 0418)
They fit a stainless steel sleeve to the bore and will supply new seals, had many cyls done there in the past.
