Headlights go on, sorta fade, flash for a microbit and then go out, both of them...
I've checked the fuses and it seems fine. Tried swapping a couple of fuses around and the headlight one tests ok. I checked the bulbs and they had blown so i replaced one but still no light hrmm.
Any ideas on what might be the problem ?
I've ruled out fuses and bulbs, seeing as the other one i plugged in didn't work. Don't think it'd be the relay as the lights saw power for a bit.
Edit: Oh yeah, parkers and high beams work.
