hey as a couple of u guys might know i'm trying to make fibreglass copies of the centre concole, and i'm stuck on how to actually remove the lighter socket from the main bit (if u look at it closely, the lighter socket seems to be on a panel of its own, and i cant get this panel off)
so far i've managed to remove all the electric bits of it, only have the metal casing and the actual panel to go.
can anyone help? i had a quick look for diys and on ftooc but didnt find anythign that can help
removing cig lighter socket
- BorepYano
- maggsy
- BorepYano
- maggsy
1. pull the stereo surround out and disconnect the wiring.
2. then around the tiny clear plastic ring that sits around the cig lighter there should be a spot to fit a screwdriver underneath and pop it out from the metal section.
3. just bang the metal section out.
i think this is how i did it but i am not sure coz it has been ages since i did it, but give it a try anyway
if you dont need to unatach the cig lighter from the matel piece then just knock the whole piece out as one.
- BorepYano
yeah i already broke thatmaggsy wrote:2. then around the tiny clear plastic ring that sits around the cig lighter there should be a spot to fit a screwdriver underneath and pop it out from the metal section.
i tried to pop it out but it wont move
- maggsy
- BorepYano
nvm, i figured it out. all i needed was a multi grip and unscrew the back of it.
feel like such an idiot now, cos i spent about 3 hrs pullng my hair out and about 2hrs asking everyone i can... hahah
thanks for the help though guys
And for those that are wondering
And for those that are wondering....
Had already done it to post up, so may as well even though youve worked it out.......
