Moderators: IMC , Club Staff
Posts: 9089 jedwabna poszewka promocja
Post
by aza013 » Fri Aug 31, 2007 8:57 pm
I just did a search and also looked in the diy and could not find any thing on this ( I may have missed it )
I just got the CAI done on the car and a vac hose from it looks like just under the intake manafold is not hooked up to any thing but befor it was atached to the air intake pipe just befor it went to the TB.
due to this the car is finding it hard to start, when I blocked the hose it starts first go can I just colse off the hose or do I kneed to atach it to the air intake pipe
I have placed a bult in the end to block and starts first go
noccers
Posts: 284 Joined: Fri Dec 16, 2005 6:00 pm
Post
by noccers » Fri Aug 31, 2007 9:41 pm
attach it to the air intake. cost me $1.80 for some tubing from autobarn to do the same thing
gawk; talk; date; wine; grep; touch; unzip; strip; touch; gasp; finger; gasp; mount; fsck; more; yes; fsck; gasp; eject; umount; make clean; make mrproper; sleep;
successful trades: d_stroy_r, shue, mxysxy, dstocks
Grue
Posts: 876 Joined: Fri Sep 17, 2004 5:00 pm
Post
by Grue » Fri Aug 31, 2007 10:06 pm
Or get a breather filter - looks like a tiny pod filter:
http://cgi.ebay.com.au/NEW-UNIVERSAL-ME ... dZViewItem
(Not recommending this seller/item, just first to catch my eye on a search)
Measure tube size first though to make sure it'll fit. Maybe Repco?
khunjeng
Posts: 4455 Joined: Mon Oct 24, 2005 5:00 pm
Post
by khunjeng » Sat Sep 01, 2007 1:26 am
Its the PCV valve/pipe.
Either put a breather or attatch it.
Posts: 23678 Joined: Fri Jan 21, 2005 6:00 pm
Post
by Bennoz » Sat Sep 01, 2007 9:21 am
khunjeng wrote: Either put a breather or attatch it.
^^ +1
Post
by Bennoz » Sat Sep 01, 2007 9:26 am
I just had a peep in my garage Aza, I've got a filter for it if you want.
However, I'd recommend hooking it up somehow. Its a metered air flow (ie measured by the ECU) & as such really should be hooked up.
Posts: 9089 Joined: Mon Mar 26, 2007 5:00 pm
Post
by aza013 » Sat Sep 01, 2007 9:56 am
ok I will get on to that thank you all for your help
