Your turn to help me! Dumb problem!
Hey all!
My central locking has been screwed for years now. Its not the common problem of the actuator going as both actuators went at the same time!!
I tried new ones does nothing! What the hell is wrong with it? Im got another central locking ECU did not help! What the hell should I check to get the damn thing working again? A lose wire could be a possibility.
Which wire should I check? Im guessing the ones from the alarm to the ECU???
My alarm doesnt go off too when I open the door when the car doors open.
Help! I hate electrics!
onnzo
Post by onnzo »
By central locking ecu- do you mean the blue one under the steering column?
Unless you want to spend hours trouble shooting I would suggest taking it to an auto elec - they should be able to find the fault pretty quicky.
I dont think it is too complex a circuit.
Mike
yeah the one below the steering!
khunjeng
Post by khunjeng »
yeah its kinda hard over a forum...
alarm never worked? does it go on? the depending on the wiring its all a bit of a mess under there.
Lets trace it back...Page 121-123 FTO Electrical wiring diagrams.
Need to know a bit more about whats going on:
a. Does central locking work with the key only (when u open drivers side)?
b. does remote work at all? is the battery in the keyless bit flat (maybe obvious)
start form there..
