aftermarket tacho
mr_f700
aftermarket tacho
Post by mr_f700 »
hey ive just purchased an aftermarket tacho but it didnt come with fitting instructions
has anyone else installed 1?
could anyone give me step by step instructions on how 2 do it?
is it hard to do???
manofwood
Post by manofwood »
why do you need 2 tachos?
mr_f700
Post by mr_f700 »
not the answer i was lookin 4 but yeah lol
JFGI? :lol:
http://www.offroaders.com/tech/Autogage-Tachometer.htm
Except you dont hook it onto the coil or MSD ignition as that link suggests, you just hook into wire 58 in the ECU:
AMACHA
Post by AMACHA »
wire 58 is a milky white wire, i plugged the red wire in to the ciggarette lighter fuse so just looped the end bit of wire around one of the legs of the fe and jammed it in and the black wire going in between the metal washer and bold just to the right of the car when u remove the panel under the steering whee lthats what i did all the best :)
AMACHA
Post by AMACHA »
quick question with the car off but the battery still connected can you remove one of the plugs from the ecu? eg the plug with wire 58 in it??
