guys i need help heater pipe
an52ep
Post by an52ep »
hi all i had heater pipe leeking water i changed the pipe now i forget which pipe go to top and which one goes to bottom there is to pipe connected to heater .one from engine bay n the other is from under radiatorr cap, now i m wondering wich one of them goes 2 top n wich one into the bottom?
thanks
Where are you talking about, inside the cabin or in the engine bay. First off, when asking for help, you need to read over what you have written to see if it makes sense and secondly, how about using some punctuation so we can understand.
If you talking about inside the engine bay, the hose that connects to the engine block, closest to the radiator cap, then it is the bottom pipe out of the firewall.
There are 2 lines from near the thermostat that go to the underside of the throttle body, the other 2 go into the heater matrix (pic below)
Mitsubishi part number is MR178783
Alternatively someone here may have some spares.
I will have some spares as soon as i source some longer ones as i need to run mine away from where the turbo is going to sit.
