tappets (I have searched )
I just would like to comferm the tappet settings for the gpx/gp motor, I did a search and these are the figers I found 0.1mm intake and 0.13mm exhaust cold and 0.16mm intake 0.21mm exhaust hot.
so can any one please tell me if this is 110% right :?:
with thanks Aza
mrx
Post by mrx »
That sounds about right, but if you want to be sure, then download the manual:
http://www.fto-ireland.com/downloads.html
Or you could download it from here :)
http://www.ftoaustralia.com/modules.php ... load&cid=2
Those numbers are right thou
thanks mrx and Ben I just finished down loading the info from the download area
thanks again :D
mrx
Post by mrx »
Ah see - turn your back for a while and we go and get all high tech ;)
DaveO
Post by DaveO »
G'day people
While on the subject. I'm off to get a 10mm extended socket to do mine and just need to know what style I should get.
Is a 3/8" drive socket long enough or do I need a 1/2" drive?
And would a 6 sided work or do I need a 12 sided one?
DaveO
bigpitty1
Post by bigpitty1 »
I used a 3/8 drive, the 1/2" drive will be too big, get a single hex the 6 side as will less likely to round off the lock nut.
DaveO wrote:G'day people
DaveO
I thought you needed to use a special tool or at least a modified one. please explain :D
DaveO
Post by DaveO »
Thanks for all of the info folks.
I'm thinking of improving the special tool by welding a nut on top so I can use a ring spanner to tighten it while still holding the screw driver on the adjuster.
Clever hay?
DaveO 8)
You know i have a phobia of the search button, i call searbutobia
I didnt see your DIY guide there bennoz wheres the link for that :lol:
