EVERY THING FTO
- Morgan
EVERY THING FTO
HEY ALL GOT EVERY THING SORTED WITH CUSTOMS
PLEASE NOT THAT NONE OF LEASE PRICES INCLUDE SHIPPING BUT I CAN GET SHIPPING CHEAP
ALL PRODUCTS ARE IMPORTED FROM JAPAN OR EU
Cusco Strut Type OS
FRONT $202 this does not include postage and handeling
REAR $202
Cusco strut TYPE ST, AS
FRONT ST $161
REAR AS $161
APP Brake lines teflon tubing and wrapped in stainless stell mesh and clear coated
$330
Most gauges on the market from heads up displays to HKS, DEFI, A'PEXI, BLITZ, SARD, PIVOT
SILICON HOSE KIT $354
Cusco Camber tops
FRONT ADJUSTABLE $230
REAR NON-ADJUSTABLE $220
A'PEXI AFC (air flow controller) digital display
$471
New APEXi AFC neo features following latest technologies.
* Completely new case design
* Compact design
* Incorporates both AFC and VAFC functions in one unit
* 16 point fuel correction
* Color FED display
* User defined button and background colors
* Inverted "anti-glare" screen
MONITOR MODE enables you to check following information.
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
A'PEXI rev/speed meter digital display
$287
REV/SPEED METER GP is a complete multi function measuring device designed to measure and monitor data such as speed, RPM, and elapsed times.
Cusco ZERO-1 Coilovers
Height adjustable
$1,600
Cusco ZERO-2 Coilovers
Height adjustable and 5 step dampen adjustable
$1,964
BLITZ MMD
$531
Optional temp sensor $135
Optional pressure sensor set $135
The color monitor can show 8 kinds of data, which are TACHO, SPEED, POWER, TEMPERATURE (water/oil), OIL PRESSURE, FUEL PRESSURE and AIR/FUEL ratio. Maximum 6 kinds of data can be shown on the screen at the same time. (Please note that temperature sensors, pressure sensors, and A/F unit are optional items.)
PIVOT SHIFT LAMPS
SSL-M single lamp and control box 12mm $110
SSL-x single shift light and box 36mm $163.5
SSL-PRO three stage shift light and box $163.5
Greddy oil cooler
$700
mounts in front of radiator
C'S short shift kit
$383
For more info please feel free to ring me on 0420835662
or email me morgan_oliver@hotmail.com and feel free to ad me to msn
or pm me
if pictures are needed email me and i will email the pic to u thanks
MORGAN OLIVER
Cusco Strut Type OS
REAR $202
FRONT ST $161
REAR AS $161
$330
Cusco Camber tops
$471
* Compact design
* Color FED display
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
$287
Height adjustable
$1,600
$1,964
BLITZ MMD
$531
PIVOT SHIFT LAMPS
Greddy oil cooler
$700
C'S short shift kit
$383
or pm me
MORGAN OLIVER
<br>DRIVEN MOTORSPORTS www.driven-motorsports.com <br></strong>S13 Nissan silvia with a s15 engine and running gear 280hp at the wheels
- maggsy
- Morgan
Bennoz wrote:Those prices are better.
yeh thanks for that i have found a better supplier in japan and cheaper transport
so hope fully i can give the savings back to you guys
- Morgan
- Supplanter
- Morgan
hey mate i can get a DEFI oil temp sensor delivered to your door for around $240Supplanter wrote:Can you get your hands on a Defi oil temperature sensor and loom? If so how much?
what colour ???? blue white or red
thanks morgan
- Supplanter
I already have the gauge (HUD actually) I just need the temp sensor.Morgan wrote:hey mate i can get a DEFI oil temp sensor delivered to your door for around $240Supplanter wrote:Can you get your hands on a Defi oil temperature sensor and loom? If so how much?
thanks morgan
- Morgan
Supplanter wrote:I already have the gauge (HUD actually) I just need the temp sensor.Morgan wrote:hey mate i can get a DEFI oil temp sensor delivered to your door for around $240Supplanter wrote:Can you get your hands on a Defi oil temperature sensor and loom? If so how much?
thanks morgan
rightio i will see what i can do then give me a day or to because i am realy sick and i will ring around ....
thanks
- Supplanter
- Morgan
- Morgan
thanks morgan
hey mate i can only get the full system no just the temp sensor but i think u should just try auto barn they would prob be the cheapest
- Supplanter
- AMACHA
- Morgan
AMACHA wrote:Please tell me you can source this part for me and have it to me before my birthday on feb1st lol im after the input shaft housing its what the thrust bearing slides on and its bolted to the bell housing and also to the flange...Help please.....im desperate
hey mate i will get straight on to it i will do my best
do u mind is its second hand or do u want new ??????
