Stepper Motor
Stepper Motor
Is the stepper motor also known as a throttle body sensor. I am going to look into a new part price for these and need the part number. I think it is MD6147635 or MD614736, but am not 100% sure.
Any help would be appreciated.
In answer to your question.... NO, the stepper motor is an idle speed control valve ,where as TPS (throttle postion sensor) tells the ECU how far the throttle is open so it then can supply correct fuel etc.
A faulty stepper motor would cause idle speed fluctuations and possibly engine cutting out when cold.
Hope this helps
Hope this helps
OK was clicking on the wrong PNC in Caps. Is this better:
MD614568 Servo Kit, throttle body
MD628054 Servo Kit, throttle body
MD628056 Servo Kit, throttle body
Im not sure what you are wanting to know now. the first two part numbers are pointing me to EVO stepper motors the last one is pointing to galant legnum, but it also shows me a v6 one underneath but it wont give me the part number
THese 3 come up in CAPS for different models of FTO. Just want to make sure they are stepper motor. Ill get a price on all 3 numbers if they actually are stepper motors (I think I have it right this time)
Yeap they definitly are all for stepper motors
- elusi0n
Seems like its idling low arent these suppose to idle like 750- 800rpm
Agreed
- aza013
- NSW Coordinator
i think about 750-850 is the correct rpm for these engines but dont qoute me. I have never heard a engine idle at 300 without stalling
- elusi0n
when i first start off the engine, it revs up to like 1.5 rpm and drops to 1 rpm. Once i put it into D then it will drop to 500 and bounces between 300 and 500. Sometimes when im driving and stop at the lights, it drops close to 100 or 200 but comes back up to 500. Never had the engine turned off due to low rpm though which is kinda weird. Sounds like it wants to but it just comes back up again.
Sounds like the stepper motor to me
Im totally shocked to hear that it is still idling at 300 -500 but anyway,
definitly agree with Dstocks totally sounds like stepper motor.
