Alternator Belt
lwrida
Alternator Belt
Post by lwrida »
Does anyone know where I can get an alternator belt?
I went to repco and they quoted me one part number 4PK0950, but saw on jono's thread that he got the 4PK0940 which is 10mm shorter apparently.
Any help with this area would be great and would love to get the car running again tomorrow.
aithním thú grá sí, aithním thú grá sí, aithním thú sibh sin mé bualadh craicinn sibh... FTO GPX 95' táirgí tuilí
[img]http://img148.imageshack.us/img148/8306/banner2ae0.jpg[/img]
jonowong
Post by jonowong »
yeh i got a few number discrepancies...
f**k it if its too loose turn the tensioner
lwrida
Post by lwrida »
jonos a good man :D
So should I get the same as you? the 940?
just pull the belt off and take it down there with you its like a 5 in job you could even do it outside the shop your getting it from. measure it up to the correct one
lwrida
Post by lwrida »
Don't have the belt to compare with.
Went down to 5zigen and on the way back the battery light came on and volts dropped.
When I got home found out the belt had come off and all I'm left with is a little braid of the old belt.
950 - 940 doesnt matter. As mentioned you can take up the slack with the tensioner. Technically it needs the 940.
yoshiba
Post by yoshiba »
Could I be having the same problem as you Iwrida...by battery light just recently came on and each time I rev it higher then 4k rpm the light disappears and once it goes back under 4k the light comes back on.
Could it be the alternator? or the belt?
yoshiba wrote:Could I be having the same problem as you Iwrida...by battery light just recently came on and each time I rev it higher then 4k rpm the light disappears and once it goes back under 4k the light comes back on.
the belt may be slipping and just grabbing at high revs but I would put my money on the alternator, but still check the belt as it would be the cheeper fix.
yoshiba
Post by yoshiba »
awesome, thanks for that aaron. ill check my alternator belt today and keep you guys posted.
btw, is the alternator belt just a direct swap? you don't have to pin it like the timing belt right?
real easy to replace, just undo tensioner, remove belt, fit new belt, redo up tensioner
Almost ^^
Gotta do that twice, cause the ps & air con belt has to come off first.
:oops: bahaha, oh yeah..... runs away and hides in corner
yoshiba
Post by yoshiba »
lol...Simon
Aaron,
That avatar picture you got there is disturbing. May I ask what that shiate is? 8O
....Oh nvm they are cow eyes! hahaha
Bennoz wrote:Almost ^^
8O Ben you noob, i think you need to lay of crack. Go outside and have your at your car and tell me what belt needs to come off first.
Simon = 1
Ben = 0
Bahahaha
Simon = 1
Ben = 0
Bahahaha
Hahahaha, I knew that was gonna give you the sh*ts :thebird:
