how is everyone manual FTO goin?
i just got an manual FTO on the 09/08/08.
i realised that my clutch and brake friction point are very bad.
CLUTCH:
i have to clutch in so far that it nearly touches the back.
but the clutch is meaty feels new though.
also when i step on the clutch its also very soft.
is this the same for u guys?
BRAKES:
same thing happens to the brakes.
gotta step on it so much that its nearly where the stage u can step on it no more.
would this be the Clutch master cylinder and brake's master cylinder?
help with Clutch and brake friction points
- nvdfto
Let the tunes decide
.:[Bosch Australia Automotive Department]:.
- nikhan
Standard FTO clutches are very soft. Thats the soft diaphram springs on the pressure plate. Nothing you can do about that without changing to a heavier duty pressure plate.
As for the pedal travel, yep as mentioned check for fluid leaks on both the master & slave cylinders. It would also be wise to do a full bleed / flush & replace the fluid. I had to replace both master & slave cylinders on mine at about 110,000 kms. Works a treat now, although originally I put a reco kit thru both items (new seals etc) but it didn't last long, especially with a heavier clutch that went in.
Brakes, same deal. Check for leaks around the master cylinder, bleed / flush the fluid from all 4 wheels, if still no good, grab a new master cylinder. I've found FTO brake masters to be fairly poor compared to other cars. For a much better feel, you can buy a master cylinder with a bigger 1 inch bore (as opposed to 7/8" on GR's & 15/16" on GPXs.)
- nvdfto
hrmm i might check it out tm or something.
well i cant drive the car anyway because its not registered due to the compliance plate disappearance.
but took it for a spin last night and i gotta admit the manual runs way better than the tiptronic. well it had good throttle responce and torque.
