SUSPENSION??
- ft04me
SUSPENSION??
Hey guys.. some of u may remeber about my misfortune within a single week of TWO accidents!
none of it is still fixed!
the guy who hit me has now done a runner and stopped contacting me so i filed a lawsuit against him today and my other collision whitch fu*ked my right suspensio is still Fu*ked after getting all the new parts from dwayne!
which is why im asking you guys why my suspension is still toeing in at the top... i've changed the lower arm, stub axle and the whole shock.. but its still toeing in... as in the top of the wheel is pointing inwards...
any suggestion as to why?? anything else i need to look at?
and dwayne what was that thing that u showed me and my dad with the cusco sway bar... the one with the adjustment thing on the top of the suspension? what does that do?
- vipfto
^^^^^^^ agreedvipfto wrote:by toeing at top i guess you mean lots of neg camber? as ben said pics would be good doubt its bent shock but is possible also have you had it aligned? lots of toe in will make it seem like top is "toeing in"...
It wouldnt have bent the crossmember as well would it?
Nah, repaced the lower control arm already. Thats what he picked up off me last weekend
- aza013
- NSW Coordinator
I concur!aza013 wrote:could it have somthing to do with the strut tower as it may have been pushed out alittle when it was hit
Meanwhile, I am in a similar situation with my Wagon, the front right has the slightest degree of camber and have replaced everything to no avail.
I was thinking of a camber correction kit, but that merely masks the issue... if it is bad enough.
- ft04me
got a wheel alignment and it looks better but its still not straight...you can slightly tell that its toeing inwards still but this time not as much...
it drives a bit better too but i get slight vibration of the steering wheel when doing past 120... i might go back next week and ask if they can have a look at it and if they can straighten it...lolz
A vibration would tend to indicate that your wheels need a balance. Youll probably find one of your rims is a little out.
- rock_it
Considering the highest legal limit on our roads is 110 ... You should be OK then ...ft04me wrote: it drives a bit better too but i get slight vibration of the steering wheel when doing past 120...
Who did the wheel alignment ... Did they look at the whole set up to see if it as all straight ... Checking all cross members and stuff
If you are really pressed for answers, go to Pedders (waits for insults), but someone here said that there was at least 1 store that was good (Penrif, or Granville I think)... See what they have to say, but for the love of God, don't let them fix it ... You could also go to K-Mac, East Coast Suspension (but I don't know where you live) ...
edit: Forgot to ask ... The vibration ... Is it on brakes or off ... The vibration could be something totally different ... Like disks could be warped, or need a machine ...
- ft04me
Hmm I mite try and get a wheel balance.... Considering I did put a new stock rim on the left front coz my old rubber was badly worn out...
I got pedders to look at it land they were the one who told me which parts replacing... I also got them to align everything for me after I've replaced the parts... It's the pedders at campbelltown...
the bit that the lower arm you grabbed off me bolts to.
