Check my prices!
Valandis91
Check my prices!
Post by Valandis91 »
Getting a few things taken care on my car on the 11th and these are the quotes i got from the same place about it... was just wondering if i was getting ripped off or not!
Service Auto - $60 Labour, $110 Fluid (includes flushing)
Change Sparkies + leads - $60-100 Labour, Part already bought
Replace CV Boots - $80 Labour, $27.50 for each aftermarket one. Brand is Motogear... anyone heard of this? are they any good?
(Maybe) Adjust Tappets - $400 Labour, $250 Parts...
Now im abit sus with the tappets costing that much...
and is there any parts that need replacing when doing in to a GPX?
cos i thought they only needed to be adjusted....
cheers
DanXbix
Post by DanXbix »
hey where about you getting it done. i just got mine back and Eurotech in northhobart are awesome. the owner rallies a Evo 9 and loves Mitsubishi cars. He really know his stuff.
JOeJOe
Re: Check my prices!
Post by JOeJOe »
Service Auto - $60 Labour, $110 Fluid (includes flushing) - Fair price, could be less. Not big of a job. What brand fluid? seems steep.
Change Sparkies + leads - $60-100 Labour, Part already bought - Fair price, just make sure they have the tool for it otherwise they'll open the manifold for nothing.
Replace CV Boots - $80 Labour, $27.50 for each aftermarket one. Brand is Motogear... anyone heard of this? are they any good? - Not sure
(Maybe) Adjust Tappets - $400 Labour, $250 Parts... - Expensive, labour should be around $250 .. GPX tappets are adjustable no no parts needed unless there's something really wrong.
How cv are you getting done? A bit on the high side if its only one but not a total ripp off.
Now i have never done tappets on a fto but from what i have read and IIRC, they only part you "MAY" need is an intake gasket and thats if you break it when taking it off. Intake gasket wouldnt cost any where near $250. A little sus on that
Nah, there's that little plastic collet that sits around the tappet head - they quite often break off. Not expensive, but can be hard to source.
pete_gpx
Post by pete_gpx »
JOeJOe wrote:Service Auto - $60 Labour, $110 Fluid (includes flushing) - Fair price, could be less. Not big of a job. What brand fluid? seems steep.
Cost me $195 for an automatic transmission service, which included flushing, oil, filter and labour.
As for the CV boots, I had mine done with my engine change. I was charged $12 each for them.
DaveO
Post by DaveO »
Valandis91 wrote:Getting a few things taken care on my car on the 11th and these are the quotes i got from the same place about it... was just wondering if i was getting ripped off or not!
cheers
Just remember that if they are doing it correctly then your up for 2 rocker cover gaskets as well as the manifold gasket. And I got quoted about $60 each for the rocker cover gaskets.
DaveO
zuihoujueding
Post by zuihoujueding »
Service auto, change sparkies sounds right.
nikhan
Post by nikhan »
$110 for oil change?? What oil are they using? If its for both engine and transmission oil it still wouldnt cost so much. Bit sus on it. My mech uses castrol magnetic and im payin only 45 bucks for the oil and 70 for the labour.
Valandis91
im getting mine done at autocraft on collins st cos thats where it was previously serviced... no one has said a bad thing about them but they are a bit pricey!
yeah i thought the tappets were a bit sus as well this is what he wrote in the email...
tappets job: it is a huge one and from memory the
replacement inlet manifold gaskets, washers etc are about $250 on their own,
plus about $400 in labour
so um yeah...
oh and just emailed them about brand of oil and its only for the auto not the engine
EDIT: Just got their email back and they said they're using Motul Dextron3
Breza
Post by Breza »
Valandis91 wrote:im getting mine done at autocraft on collins st cos thats where it was previously serviced... no one has said a bad thing about them but they are a bit pricey!
so um yeah...
Tappets sound about right.........
Autocraft are probably expecting the worst after having mine and DanXbix's in there.
In my case they hade to replace some seals, some little plastic collars and a couple of other bits that don't come to mind in the top end when I had it done the first time around.
Better to under promise and over deliver than the other way around.
Mind you, I don't need to go there any more. :-)
Cheers
Chris
Bennoz wrote:Nah, there's that little plastic collet that sits around the tappet head - they quite often break off. Not expensive, but can be hard to source.
if these are gon Ben would it make the tappets go out of ajustment faster?
