Limited Slip Diffs (LSD's)
RichardB
Post by RichardB »
From that I can tell, there are 4 brands of after market LSD available that will fit the FTO
Cusco do a type RA and a type MZ, in both 1 way and 1.5 way
http://www.cusco.co.jp/en/parts_product ... ypemz.html
Quaife do their ATB Diff (Automatic Torque Biasing Helical LSD)
http://www.quaife.co.uk/Mitsubishi-Ecli ... fferential
Phantom Grip do one
http://www.phantomgrip.com/index-3.html
Kaaz Do on
http://www.kaazusa.com/intro2.html
But which would be the best for a FWD drag car and why?
Boris
Post by Boris »
Hm, i'm not sure on those other brands but I personally would stick to the Cusco 1 way lsd's for a FF car.
FTEvolution
Post by FTEvolution »
Finally some info on Diffs, I have never known what to look for when searching the sites.
You link to an Eclipse diff from Quaife, is that the same as an FTO diff? GR? Would that fit the 4 speed tip? Or should I just contact them directly?
Smooth and sleepy
SG
Post by SG »
The cusco MZ lsd is labelled as a drag racing diff on their jp website iirc, and their RS is labeled as a street diff. Not too sure what the difference is.. their probly both noisey but the RS would put up less of a fuss when you turn.. the MZ i have if im going 50kph and turn the wheel slightly and let go it'll snap back to center agressively on its own, but i havent experienced any other fwd diffs before
SG wrote:The cusco MZ lsd is labelled as a drag racing diff on their jp website iirc, and their RS is labeled as a street diff. Not too sure what the difference is.. their probly both noisey but the RS would put up less of a fuss when you turn.. the MZ i have if im going 50kph and turn the wheel slightly and let go it'll snap back to center agressively on its own, but i havent experienced any other fwd diffs before
SG, did you have the plates rearranged to reduce pre load, or just went in 'as is' out of the box?
SG
Post by SG »
went as-is
