WTB: Suspension bushes + steering reck
- kosto
Hi i went pedders and got my suspension checked and they said i need new lower bushes on the front and that the steering reck boot is split.does anyone know where i can get these parts
- Robbie
- vipfto
bushes camskill get the anti-lift ones
but they need to be press fit
rack boots can get universal ones or car specefic ones from repco etc, should be same as galant, as for fitting relativly easy just need to remove tie rod end (count turns) pull old boot off/ new one on, tie it up then reassemble (counting turns of tie rod end)
then get wheel alignment as toe will be affected esp if you got the counting of turns wrong
@ robbie if ya need i'm here to help
- Robbie
