want to lower my FTO
- Timmy_fto_
um..im just thinkin to lower my car...
but im just wonderin wats the difference between Tein and Kings
The price is obviously differernt..
and are kings good...??
- mz_madz
- aza013
- NSW Coordinator
Re: want to lower my FTO
the Tein's are coilovers and kings are springs that are a replasment to your factory springs.Timmy_fto_ wrote:um..im just thinkin to lower my car...
- koolio1234
Correct, hence the expensive nature of teins. If your looking for adjustability, go with the teins as they have lots of fun settings to try to get max performance in track settings.aza013 wrote:the Tein's are coilovers and kings are springs that are a replasment to your factory springs.Timmy_fto_ wrote:um..im just thinkin to lower my car...
If you just want to lower the car and still have better than stock suspension, go with the king springs with some kyb excel g shocks.
- Timmy_fto_
- koolio1234
Yes i would say they are better for performance. Would cost around the $1500 mark for a set of 4. Don't forget that they are coilovers, and coilovers are usually expensive. But they're worth it.Timmy_fto_ wrote:so Teins are better for performance right??
does anyone know how much would it cost...
Your cheaper option would be to go for the kyb excel g shocks and king springs, that'd cost around $800 - $1000 including fitting, aligning,etc
Youll also find the teins are QUITE stiff. Itll give you a hard ride even on the softer damper settings. If you have a lot of rough roads around where you drive, id be hesitant to go down that path (especially if they are Jpa spec as these will be especially hard)
- FTEvolution
Could always customise your coilovers, as in get the spring rates custom ordered with something comfortable.
Then the best of both worlds, nice ride quality and adjustability...
Smooth and sleepy
Smooth and sleepy
- bushido
How did we go from lowering the car to coilovers?
As you all know, I am not an advocate of using coilovers on the road.
A set of King springs will cost you about $300 & drop the car 2 inches at the front & 1.5 at the rear. A number of people here use them without issue. The Tein springs will do the same but as mentioned they are substantially stiffer.
- bushido
Have the street spec ones.nicholas wrote:What setting are you running steve?
http://justjap.com/store/product.php?pr ... 289&page=2
Slightly more exxie now though
- mr-charisma
you've also go the option of whiteline springs as well, which are just as good / better depending who you talk to. ..
www.whiteline.com.au
- vipfto
totally agree ^Bennoz wrote:How did we go from lowering the car to coilovers?
I use kings with good shocks, bushes, camber bolt and braces car feels good enough for odd track days and not too stiff on the street
unless you plan on turning it into a monster track weapon i wouldnt bother with coilovers esp for everday use
- zuihoujueding
- mr-charisma
blah blah, we all know your a grandpa lolBennoz wrote:How did we go from lowering the car to coilovers?
Coilover's FTW
- koolio1234
+1I8A4RE wrote:blah blah, we all know your a grandpa lolBennoz wrote:How did we go from lowering the car to coilovers?
Coilover's FTW
Nah, Do what would be more comfortable for you/fits your budget. Got to say though, Ive never been in a fto that handled as well as mine the coilovers. If your willing to put up with their stiffness, they are AWESOME
I've been in your car with its previous owner. Gave me stretch mark on my boobs over speed humpskoolio1234 wrote:+1I8A4RE wrote:blah blah, we all know your a grandpa lolBennoz wrote:How did we go from lowering the car to coilovers?
Coilover's FTW![]()
As Supplanter wrote:Get off my lawn!!
