Guess what im about to buy..... Frankenstein resurected!
Valandis91
Post by Valandis91 »
the frankenstein engine from RPW
:D
this is no joke i am being one hundred per cent serious...
bag me as much as u want but im doing it!
:D
im excited!
just not looking forward for the wait for them to build it...
its how i like to stimulate the economy :)
nvr2low
Post by nvr2low »
wow sh*t man that is gonna be bloody awesome mate. good luck with it
koolio1234
Post by koolio1234 »
8O Holy Crap.....AAAAHHHH its frankenstein, RUN! :twisted:
You going to need a stand alone?
Post up the specs, cant find it on the website.
Valandis91
yeah it will need a stand alone...
im pretty sure the standard 6a12 wouldnt be able to handle this baby!
it is going to be a beast
Valandis91
1.
Mitsubishi 6A13 DOHC Mivec Hybrid Engine utilising 6A12 DOHC Mivec heads onto a 6A13 DOHC Turbo Engine block
2.
RPW / CP Custom 12.5 : 1 Forged pistons suitable for NOS
3.
Forged Steel 6A13 Conrods
4.
Engine bored, honed and acid cleaned
5.
RPW Ported and Polished Cylinder heads
6.
RPW Valve springs and Vernier Camshaft Gears
7.
RPW Stage 1 Improved Camshafts on high rpm lobes, custom 1/2 Grind improvement on low rpm lobes
1.
RPW Modified 3-1 Extractors, custom long tube "Race Design" to accomodate longer engine block
2.
RPW Modified customed aluminium billet flywheel with heavy duty cushioned multi paddle clutch
3.
Haltech E11 ECU to control everything
4.
RPW Modified intake manifold with larger 65mm throttle body
5.
Larger 240cc Injectors to replace the stock 6A12 165cc Injectors
koolio1234
^^^Nice :D
Any plans on when they're gonna start the project?
Wow, wonder what level of porting the heads have gone through.
How much it costing? and what ecu you have planned?
Valandis91
still in discussions with them...
will give them a ring tomorrow to sort some things out...
they said it will take about 3 to 4 months to build :(
thats gonna be a very slow few months!
mr-charisma
Post by mr-charisma »
cool stuff mate ...
Definitely gonna be a slow 6 months .. I think I would die from that much anticipation..
How much is the whole project going to cost you?
Valandis91
still sortingg out the nitty gritty...
but yes i think i will die...
holy sh*t man that is fu'&ing kick arse!
I read they built one then stripped and sold off as parts, was wondering how long it would take someone to this :twisted:
Valandis91
so after a lengthy discussion with my mechanic it seems that this would be very expensive to run...
with such a high compression it would require race fuel which is above $6 a litre! 8O
it would chew through oil and petrol...
it would need a rebuild every 15,000kms... :evil:
but it would be freakin awesome!
i just dont have the funds to keep it runnning like that...
ive emailed rpw to see if they could tune it down a bit by lowering the compression and having lesser cams but they havent gotten back to me...
so now we wait and see...
if they cant do anything then i mite go the gr turbo path...
That will cost you at least 20 grand to get right. RPW aint cheap.
Save your coin, either put a snail on a GR ($6000) or do the 6A13 ($10,000)
nvr2low
Post by nvr2low »
wow man why not go down the 6a13 path look what happened to sams car when he went 6a12 gr turbo. but then look at simons his works sweet
nvr2low wrote:wow man why not go down the 6a13 path look what happened to sams car when he went 6a12 gr turbo. but then look at simons his works sweet
so man what are you telling him? to do it or not :?
I agree with ben and (maybe) nvr2low :lol:
nvr2low
Post by nvr2low »
ok just get the 6a13tt their happy simon haha
mr-charisma
In addition to what Ben said. .there is a reason why RPW scrapped the project ..
It would be awesome .. No argument .. but it does have to be a "money is no object" project ..
As Ben & Mitch said .. 'tis a better spend of the money to go 6A13 or plain turbo .. even dropping in a 4g63 would be better & still pretty unique.. not sure if it's been done in Aus yet..
nvr2low
Post by nvr2low »
yeah mate it has been done before i think the car with the number plates fto evo or evo fto it was for sale on this forum mate
do the 4g63, would love someone to tackle that.
I nominate you! :lol:
The r35 requires a similar job to be done to it every XXXXXkm and it makes a balls load of power.
so unless this engine can do equal, then yeah, not worth it.
you would be spending a LOT to keep it compliance happy, and then you'd simply hinder it.
