G4 Street Spec Coilover Suspension Kit - Mitsubishi FTO
Oliver89
Post by Oliver89 »
Hey Guy's,
My Shocks are SHOT! and i am looking at getting coil over's for my FTO.
Just came across these on justjap website
- Complete Kit
- 1 Year Warranty
- Spring Rates 7.5 (F) 7.2 (R) Kg/mm
- 36 Way Damper & Height Adjustable
- Teflon Coated Thread
- Monotube Design
- Fully Rebuildable in Australia
SKU G4SUSKIT-FTOSTREET
Quantity in stock 2 item(s) available
Weight 15.00 kg
Price: AUD 1399.00
Link :
http://justjap.com/store/product.php?pr ... t=0&page=1
Im planning on getting these installed soon, Just want to hear some response from you guy's if anyone is aware about these coil overs ? Any good ?
Thanks for your help :)
Proud Owner Of a White ( Version R ) Aero Series 1998 Mitsubishi FTO 24v 2L Mivec Engine. Fresh Import.
[img]http://img197.imageshack.us/img197/2568/fbsig.jpg[/img]
J
Post by J »
im sure someone on here is selling a used set for 600bux, dont know if it was dwayne or sam.
Oliver89
Post by Oliver89 »
jay6 wrote:im sure someone on here is selling a used set for 600bux, dont know if it was dwayne or sam.
I havent had any luck with used parts, Im not interested in used parts i need new parts.
But thanks anyway.
FTEvolution
Post by FTEvolution »
G4's/D2's... all the same really
Good quality for what they are (damn strong actually)
Make sure you get some (softer than they specify) springs or you will get sick of them real quick
Smooth and sleepy
Yeah mate i have them in mine and are brillant but definitly get softer spring rates around the 5 mark is about as stiff as i would go. Well thats actually how stiff i did go and i wouldnt go any stiffer.
nicholas
Post by nicholas »
How are you planning on getting those supernew coilovers into your car when it has a big shiny clamp on it?
Resident Asshole.
Oliver89
Post by Oliver89 »
nicholas wrote:How are you planning on getting those supernew coilovers into your car when it has a big shiny clamp on it?
Mate your way off topic my clamp has been OFF for ages , can you stick to the topic please the car has been on the road since late febuary.
Hmm i'll ask the guy and tell him what I8A4RE said & see what he says about it.
I sha'll have them in this weekend hopefully if not the following weekend.
Thanks.
nicholas
Post by nicholas »
Okay mate, fine.
If you want some serious advice - coilovers are a performance modification. Those wheels you have on it are pretty much a direct contradiction of 'performance modification'.
Sell up the big shiny dishes, put some decent wheels on it, and you'll enjoy those new coilovers a whole lot more.
And then when you're done, you can even make another one of your famous youtube videos about the whole experience :lol:
Resident Asshole.
FTEvolution
nicholas wrote:Okay mate, fine.
bad day nicholas?
Smooth and sleepy
koolio1234
Post by koolio1234 »
Im running D2 coilovers and they are great, they are 9kgs and are deadly stiff. Not to comfy for normal road use though, mainly for track.
Rock_it has G4 coilovers I think.
mr-charisma
Post by mr-charisma »
I8A4RE wrote:Yeah mate i have them in mine and are brillant but definitly get softer spring rates around the 5 mark is about as stiff as i would go. Well thats actually how stiff i did go and i wouldnt go any stiffer.
That's more use of the word "stiff" than should ever be put in the same sentence! 8O :lol:
nicholas
Post by nicholas »
Yeah, mine are so stiff you can't actually get the power down on anything less than a racetrack.
Definitely opt for the 'softer' end of the coilover spectrum; you car will thank you for it (by not falling apart in a few years time :lol: )
Resident Asshole.
koolio1234 wrote:Im running D2 coilovers and they are great, they are 9kgs and are deadly stiff. Not to comfy for normal road use though, mainly for track.
oh now i understand why ben is so against coilovers now
I've explained it before, using such stiff springs on the roads is actually dangerous. By the time you hit a bump, the spring will snap the shock back down so fast, you haven't actually travelled past the bump - effectively bouncing yourself off the top of the bump & possibly the road if you are cornering at pace.
As for the product in question, Im told they are a good product - but as mentioned, specify a softer spring rate such as 4kg front & 3kg rear for street use.
koolio1234
ive heard of d2/g4 coilover horror stories that involved the springs snapping and shocks failing when someone tried 'drifting' with them. :lol:
If i could get springs with lower rates I would, not sure if i can, does anybody know where i could get d2 replacement softer springs??
J
Post by J »
Bennoz wrote:I've explained it before, using such stiff springs on the roads is actually dangerous. By the time you hit a bump, the spring will snap the shock back down so fast, you haven't actually travelled past the bump - effectively bouncing yourself off the top of the bump & possibly the road if you are cornering at pace.
Agreed, whilst i dont have coilies my stiff springs can be a bit dangelrous at times. Half the time i find myself skipping across a turn because the car gets off the ground because of little bumps.
I was sliding through some of the corners on the bonfire trip. Although this may be partly the problem with the nangkangs that wrap my new wheels.
------ coilovers will benifit even with his chromes mate. Its not like they weigh 30kgs each. Im sure he's getting coilies for the lowering adjustments and camber aswell
bushido
Post by bushido »
Shoudl have done a search Olly. I have the exact ones you put a link for. Perfect imo. I like the stiffness and I havent had anything wrong go with them. Justjap will replace the whole thing if they are faulty so what do you have to lose. Get them!
Fulltiltorgasm
Post by Fulltiltorgasm »
im thinking of replacing my front shocks, how does the stock suspension (macpheron struts i think) differ from Coilovers ??
Oliver89
Post by Oliver89 »
Well to tell you the truth mate , thanks for your smart ass reply ass**** But im not planning the race the car , just for everyday road use.
I find it better for my budget as well , ive been given quotes on shocks and even re-building them are just wayy to much out of my budget.
These coil overs are fantastic at a fantastic price , I will indeed get a softer 3kg or 4kg spriing rate but indeed not planning to race my car at anytime.
My wheels are just fine thanks , if you dont have anything fkn nice to say dont say it at all. I dont wanna here your bullshit on here , keep it to yourself ye thanks mate.
Anyways thanks for your rubbish advice nick.
Everyone else thanks for your attention =) much appreciated. :)
nicholas
Post by nicholas »
Oliver89 wrote: But im not planning the race the car , just for everyday road use.
I thought your specialty was combining the two?
Anyway, whatever dude, I was just trying to be helpful :D
Resident Asshole.
