FS: 8mm Magnecor Leads to suit GR
Guys, I no longer have a need for these.
As per the title, they are 8mm Magnecor ignition leads to suit a Non Mivec only. They will not fit a GPX.
Great addition for those of you looking for more from your car.
NB: These are also not suitable to for turbo applications that utilise Microtech or Haltech standalone ECUs.
Asking $100 plus postage if required.
pete_gpx
Post by pete_gpx »
*thread hijack*
So, I would be after a set of 8.5mm leads for my GPX?
pete_gpx wrote:*thread hijack*
No you can 8.5 or 8mm. Seriously you would not be able to tell the difference.
Why they wont fit the gpx is they have different length stems (the pat that you put down into the rocker cover)
This^^
8.5's are substantially more expensive for no good reason - apart from the fact they are a @#$% to try & slide into the plug boots cause they are too thick.
pete_gpx
Post by pete_gpx »
So I would be after the 8mm leads that are listed on CamSkill as being suitable for the GPX?
[/thread hijack]
sublime19
Sooty!
Post by sublime19 »
Sold - I'll take em.
Can I give you a money for these in like 1 weeks time though? I deposit all my pay into an account where I can't pull it out and living on pocketmoney by the week :?
Yep
