wont idle when cold
- col2560
wont idle when cold
wont idle when cold, and when its warm it still fluctuates between about 1,000 and zero and almost stalls, up and down like a yoyo swapped the stepper from my son's car but still the same, so it's not that.
any suggestions welcome.
thanks guys.
thanks guys.
I also have this problem with mine, especially in the cold tassie winters. I've had it investigated a couple of times and have also had the stepper motor replaced. I have so far been told that its just something the FTO does due to an automatic choke? I find that if i get in and hold the revs at about 2,000 for a minute or so its fine! But i'm not sure if it is indeed a problem with the car or just the Automatic choke struggling in the cold weather! Maybe some one could help us both out with an answer to this! Any help appreciated Guys & Gals!
- col2560
- aza013
- NSW Coordinator
- col2560
- aza013
- NSW Coordinator
- aza013
- NSW Coordinator
- col2560
- col2560
ok. read error code as 32-vacuum sensor.
swapped it for my son's sensor, still the same problem. so i swapped it back and re-set the codes by disconnecting battery for 30 odd seconds. tried restarting the car, still the same and error code now says no errors (fast flashes continuessly)
what's next?? lol
it's so handy having the other car for parts, saves buying and trying.
what's next?? lol
O2 sensor, ecu, or maybe a blocked or leaking vacuum sensor line
- col2560
- col2560
- FTEvolution
- col2560
- col2560
- col2560
