Moderators: IMC , Club Staff
Posts: 23678 jedwabna poszewka promocja
Post
by Bennoz » Thu Jul 30, 2009 9:22 am
Why you ask?
This Kaz's sons car. A 2.4L 86 Nissan Navara ute..
It rolled in the driveway the other day with a blown head gasket, so it was a good excuse to use up some old Weber's I had sitting under my workbench
Figured some of you old timers would appreciate the old skool go fast bits.
2 x 45mm DCOE carbs
New manifold to suit
Extractors
Mid range Crow Cam
Converted to double row timing chain from single
Thermo fan added to remove old fixed unit
Reco'ed the head with some mild porting & 1mm taken off the deck height to bump up compression
Will pop up more piccies up as I aseemble it
Posts: 23678 Joined: Fri Jan 21, 2005 6:00 pm
Post
by Bennoz » Thu Jul 30, 2009 6:53 pm
Posts: 4154 Joined: Mon Oct 29, 2007 5:00 pm
Post
by vipfto » Thu Jul 30, 2009 10:12 pm
ha ha just class
nice to see some of us still know how to beef up some old school motors
Post
by Bennoz » Fri Jul 31, 2009 8:38 am
Hehe, its gonna be a sleeper. Fairly ordinary looking old ute with that under the bonnet! Wish I could put Webers on an FTO
col2560
Posts: 434 Joined: Fri Jun 06, 2008 5:00 pm
Post
by col2560 » Fri Jul 31, 2009 10:21 am
why can't you?
might be a solution to my "stepper motor" problems lol i kinda miss my old 720 ute. is this navara an 1800cc? was just an upgraded 180b motor, which was an upgraded datsun 1600, plenty of go-fast bits made for them !!!
Post
by Bennoz » Fri Jul 31, 2009 11:35 am
Nah its actually a Z24 block (2.4L)
A few bits made for them, not a huge amount thou. I was surprised we ere able to surce a dual DCOE manifold for it, let alone a hot cam!
Post
by vipfto » Fri Jul 31, 2009 2:42 pm
col2560 wrote: why can't you?
cant put carbs on fto mate its injected, well you can but no point and lots of pissing around
Tippin
Posts: 1663 Joined: Wed Feb 27, 2008 6:00 pm
Post
by Tippin » Fri Jul 31, 2009 4:37 pm
put a pic up of the exterior bennoz
col2560
Post
by col2560 » Fri Jul 31, 2009 5:35 pm
going by the condition of the engine bay, the shiney head and carbs might just be the best part of the whole car !!!
Posts: 9089 Joined: Mon Mar 26, 2007 5:00 pm
Post
by aza013 » Fri Jul 31, 2009 9:36 pm
koolio1234
Posts: 2574 Joined: Sat Oct 04, 2008 5:00 pm
Post
by koolio1234 » Sat Aug 01, 2009 5:01 am
Very nice...I can definitely appreciate a sleeper
Post
by Bennoz » Tue Sep 29, 2009 8:36 am
Shes' up & running now. Its a cranky little sob
Gotta pick her up from the tuner this morning.
Post
by aza013 » Tue Sep 29, 2009 3:40 pm
looks great how does it run?
koolio1234
Post
by koolio1234 » Tue Sep 29, 2009 11:15 pm
Im guessing she runs a bit rough
should have a nice sound
Post
by Bennoz » Wed Sep 30, 2009 7:57 am
Actually runs pretty nice! Cuts loose when you open those carbs up thou, you can see the fuel gauge plummet
Post
by Bennoz » Tue Nov 03, 2009 7:25 am
Did a run down @ Eastern Creek the other night, just for the fun of it. The 2 tonne bastard managed a 17.4
Webers ftmfw!
We're gonna try some larger jets & pissing off the air filters (in favour of ram tubes) to see what she does. I reckon those changes, plus some new rubber on the rear, we'll get her in the 16's. Stock FTO owers look out! For a cranky old blue ute!
Post
by Bennoz » Fri Nov 06, 2009 4:55 pm
Well, easy come, easy go..
Last night she sheared off the timing chain tensioner & dropped a majority of the timing gear into the sump. Bent every valve & cracked every piston
SR20 time. Anyone know where I could source one cheap (engine / box / loom / ECU) that would be great!
koolio1234
Post
by koolio1234 » Fri Nov 06, 2009 6:56 pm
Bennoz wrote: Well, easy come, easy go..
try pulsar forums (might have to sign up to get access to the for sale section)
or this on eBay --->
http://cgi.ebay.com.au/Nissan-SR20-Non- ... 19b792d1b3
Its @ $800 and just need a manifold + turbo to make it a sr20det
Downside is its in victoria.
I've seen non-turbo sr20's go for $400-600 on ebay, just have to wait for one to come along.
pete_gpx
Posts: 697 Joined: Sat Aug 16, 2008 5:00 pm
Post
by pete_gpx » Sat Nov 07, 2009 3:18 am
Wouldn't he be looking for a RWD SR20? In that case, what help would the Pulsar forums be?
Post
by Bennoz » Sat Nov 07, 2009 9:56 am
This ^
Will need to be Red top with box from the likes of a 180 / S13 etc
