FS: ICE Performance Ignition Leads to suit GR *SOLD*
Hi Guys,
Selling these leads as they are no longer required as Im now running individual coil packs.
They are the Performance 2000 series 5mm leads in red, rating at 200 ohm resistance, which is 10 times less OHM / resistance over stock leads.
Why is lower resistance good? Lower resistance means better conductivity, more charge hitting your spark plugs and less heat in the leads themselves. All good things.
People who have fitted the ICE ignition leads have reported fuel economy gains, easier starting, cleaner revving and definitely noticeable improvements.
I paid $140 new and they have done all of about about 3 hours on a dyno. Will sell for $120 including postage.
These are silicone surpressed & as such are suitable for use with interferance senstive ECU's like Haltechs.
Unsure if they will fit a GPX. Im sure someone will have a set of both to compare. From memory some of the lengths differ due to the rocker cover differences.
Sold!
