the 3a that i have is the 3" one, the tfi, which iv only ever used for about 15 mins for testing purposes was 4"..
i think you'd need a 3" metal pipe or a hard pipe, as the inlet on the 3a is soft... ill post a pic later after work, the top of it is the carbon style.. only used it for about 2 days as i bought the uas unifilter anyway. so the 3a basically brand new but with a tiny bit of dirt which u could not really see..
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
Heres the pix by the way. as you can see on one of them, the filter is too small for the stock pipe, you would need to buy a proper metal intake pipe. and the inlet of the filter is soft.
it depends, if its a GR, then you can attach the adapter to the MAF sensor, but for a gpx, what can you use for, say, the stock pipe, considering how hard it is to find a metal intake pipe ?
97 GPX Icelle Blue
FTO[For The Orgasm]
