High Flow Sports vs Cannon Mufflers
- StraydoG
Getting my exhaust done soon and I have the option, what would be better to go for?
Im pretty much looking for something thats not stupidly loud, especially for under 3000rpm.
Also I know everyone will have an opinion but good tip size? Something that blends in well.
- Gholdwayne
Re: High Flow Sports vs Cannon Mufflers
the 2 mufflers are going to be similar from what i see as both of them will be free flowing. for sound, the cannon is going to be louder but can be calmed down with a resonator or two.
As for your choices, coming from a cannon muffler, i would personally look into trying the muffler with dual outlets tips like the stock ones, either 2.5 or 3". cannons tend to make that open loud sound. try the varex mufflers, or magnaflow.
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- nicholas
I've had both on an FTO, and I would never go with canon over sports ever again.
It's all personal opinion, and also how you set it up, but to me sports exhaust have that great combination of quiet around town and excellent sounding when you put your foot down
Resident Asshole.
- bushido
There is also a correlation in terms of sound quality and the quality of the muffler. Cheapy cannon mufflers are sh*t.
- zuihoujueding
crappy canons sounds like farting.
try x-force with dual tip. sounds great and discreet.
- alekazam
the x-force varex remote control muffler is good not just a gimmick i had mine for 6 months and still use it daley.
plus a cannon muffler makes you look more like a street racer. here is some vid of mine
- zuihoujueding
holy sh*t......sounds like heaven!
- Kustom
alekazam wrote:the x-force varex remote control muffler is good not just a gimmick i had mine for 6 months and still use it daley.
It does sound very very nice, where did you get it done btw?
- StraydoG
That does sound fecking awesome
Cheers guys, will go for a sports muffler, just got to decide on the tip now
- alekazam
thanks guys i got it done at brisbane exhaust http://www.brisbane-exhaust.com.au/products.html as thay stock the varex id recomend you put a resonator upstream if you want to have it on its loud setting all the time.
- Gholdwayne
yeah the varex is nice, i love mine, its pretty much 2 mufflers in one, straight through and chambered. has a nice deep rumble on back off
StraydoG - get the dual tips with one sticking out more than the other a little bit like the stock ones and slightly thicker sides
Alekazam, what did you mean by upstream?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- alekazam
between the cat and muffler
- Gholdwayne
alekazam wrote:between the cat and muffler
Oh ok, i thought it was a specific point in the catback.. but then since upstream means within the catback, i dont suppose there is something else on the other hand ?
i dont want to imagine downstream means that its in the downpipes
ah well...
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- StraydoG
Nice, got it all done with y-pipes and flexi joint changed too for $880NZD. With the recommended twin tip!
Changing from the exhaust subject, will an intake system help much for more responce and does it actually help fuel consumption very much? Just wondering if I am better to get a new air filter or a whole pod filter, piping, ducting etc.
- Gholdwayne
yeah the air filter works in conjunction with an upgraded exhaust, and the other way around too. makes your car breathe better as experts here say. I heard that the best intake upgrade is a boxed pod filter with a cold air feed fromt he front bumper, then the intake pipe has to be changed altogether as the factory one is restrictive as we all know.. you can improvise something like a 76mm system from the throttle body to the filter. maybe a 90degree silicone elbow, straight stainless 3" pipe, and i think another 45degree silicone elbow and another small 3" pipe for the filter - if your lucky you might be able to use the existing airbox as an enclosure like member vipfto did if u use an same size HKS pod or same size other brand pod.
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- koolio1234
Get the UAS intake kit and make a CAI for it. There's a 8-10kw at the wheels gain (the stock intake pipe and filter setup is fairly restrictive especially for a high powered, low displacement N/A engine like the 6a12).
- Gholdwayne
then again i bought the last set and john said ftoaus would have to have something like 10~15 ppl for them to start making them again as they're expensive to make
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- J
2.5 piping to dual 2.5 outlets... no resonator, no exhaust box - all straight pipe
- koolio1234
that would be pretty loudJ wrote:2.5 piping to dual 2.5 outlets... no resonator, no exhaust box - all straight pipe
- Kustom
Sorry guys but bit of a nub here, Resonator = Make it quieter?koolio1234 wrote:that would be pretty loudJ wrote:2.5 piping to dual 2.5 outlets... no resonator, no exhaust box - all straight pipe
