gpx mivec and non mivec timing belt bearing ?????
andy123
Post by andy123 »
are they interchangeable ?
Re: gpx mivec and non mivec timing belt bearing ?????
Yep, same bearing. MD316826
andy123
Post by andy123 »
what about the bearing on top of the water pump
Above the pump or on the pump itself? The one I was referring to was the one above the pump. The idler bearing.
andy123
Post by andy123 »
what about the pump it self and the bearing on the tensioner
Pump is generic. Can be bought from any auto shop, ask for HJ galant.
Tensioner is mitsi specific.
andy123
Post by andy123 »
is that mean the hj galant water pump are the same ?
is the mivec and non mivec tensioner bearing the same ?
andy123
Post by andy123 »
and is the water pump for the non and mivec the same ?
Water pump is common to all 6Axx series engines. Mivec, Non Mivec doesn't matter.
The bearing on the tensioner is the same too.
The only difference between mivec & non mivec on that end of the motor, is the cam gears & the belts lengths.
andy123
Post by andy123 »
thank you
